input capacitor ripple current rating for push-pull - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 27th February 2007, 04:28 PM   #1
zilog is offline zilog  Sweden
Default input capacitor ripple current rating for push-pull
I want my smps with input voltage range 10-16V, maximum D=0.8 and assumed Eff=0.8 to withstand 150W continuous output power. Calculations from Pressman give the rms current through each transformer leg is 15*1.56*sqrt(0.4) = 14.8Arms giving a total Irms of 2*14.8 ~30A through the center tap leg. Since I will be feeding this smps from a car battery through inductive and resistive cables, am I correct to assue that the input capacitor bank will see the full 30Arms ripple current? If so, why do every commercial car amp seem so under-rated with respect to rms rating, there is usually only a few caps on the input while my calculations tell me that I need 12-13 pieces of 2200uF MV-WX caps @ 16V. I know that these caps can withstand 2-3 times that rms current at 25 degC as opposed to the specifiec 105 degC, but still..
Any opinions on this?
Its not only that I need high ripple endurance, I also need low ESR and a couple mF to reduce voltage droop.
Old 27th February 2007, 07:58 PM   #2
Needing such large capacitor banks implies that the input to your transformer is experiencing voltage droop, which you do not want anyway. Normally, the cables going to the battery are thick enough to permit the battery to supply most of the peak current.
Old 27th February 2007, 10:31 PM   #3
zilog,
It's a good idea to put some high quality capacitance across the bus near the power switches and transformer. You could calculate the impedance of the cable, but at high frequencies it will be large. Assuming that most of the high frequency current is flowing through the caps you can use this to find the cap current.
http://www.geocities.com/CapeCanaveral/Lab/9643/rms.htm
Enter the data for you waveform and then click on one of the calculation boxes.
Obviously, only the AC component flows through the caps - not the DC component.
Rick
Old 28th February 2007, 10:08 AM   #4
I have plated a bit with the maths now, and have come up with much better numbers. For a push-pull converter with total duty-cycle of 2*D (D being per switch leg) and I_{fp} being the equivalent flap-topped current of the trapezoidal currents in the switcher legs,
I_{rms} = I_{fp}^2\sqrt{2D}
I_{DC} = 2DI_{fp}
I_{AC} = \sqrt{I_{rms}^2 - I_{DC}^2}
This gives a DC current of 18.72A and an AC current of 9.3A if I operate the smps with Eff = 0.8, 2*D = 0.8, Vin = 10V and Pout = 150W. Guess 5x1000uF MV-WX (1.82Arms per piece) will suit my needs then.
6T9 push pull with Cathode Coupled input Brit01 Tubes / Valves 5 18th January 2009 11:58 AM
estimating ripple current rating earl of sodbury Parts 16 6th June 2008 10:54 AM
what happens when current mode push-pull goes discontinuous? zilog Power Supplies 8 10th January 2007 07:39 PM
Magnetizing Current in Push-Pull Converter scottieman Power Supplies 3 28th January 2005 06:47 AM
Power rating for push pull configuration question miked15 Tubes / Valves 4 15th May 2002 02:50 AM
Copyright 1999-2017 diyAudio
