Microphone power supply - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th February 2007, 06:24 PM   #1
Default Microphone power supply
Has anyone here built a high quality power supply for a condenser microphone?
I am currently building a converter for my Sennheiser MKH416T microphone, based on this circuit:
http://www.uneeda-audio.com/phantom/p48t122.jpg
As you can see it converts 48v from any phantom supply to 12v to feed the T supply. But I would like to improve on the zener regulator.
Current drain is very low: just 6mA.
Suggestions?
Carlos
Old 28th February 2007, 04:25 AM   #2
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
I use battery for mine mic,I think this way is more easy.
Z
Old 28th February 2007, 05:27 AM   #3
imix500 is offline imix500  United States
imix500's Avatar
We have a bunch of T-power adapters at work for the old 418's and such. I'll take one apart next time I'm there. They're old though, so they might also be zener based.
Old 28th February 2007, 09:34 PM   #4
This circuit will work very well - and there is no real reason to try and improve on the zener regulation.
Remember that with a Phantom supply - you have very limited current available, so the use of any sophisticated regulation is difficult. Also the + 48 volt supply will be very quiet so no additional ripple reduction is required.
Of course if you are building a mains powered 'T' power microphone supply - then you can certainly play with the regulation!
John
John Audio
B&K microphone power supply - help needed TheoM Power Supplies 83 22nd February 2017 01:27 PM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 05:10 PM
microphone + headphones + battery power truthbetold Parts 2 17th December 2008 11:41 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 02:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Copyright 1999-2017 diyAudio
