Advice wanted - regulated PSU for Vin 42 V / Vout 25-40 V
Old 15th February 2007, 02:16 PM   #1
Groundloops is offline Groundloops
Im amazed!
Groundloops's Avatar
Question Advice wanted - regulated PSU for Vin 42 V / Vout 25-40 V
I want to build kinda "universal amplifier PSU", adjustable from 25 to 40 volts and giving enough current to drive GC, MyRev, Symasym and others. I got a pair of 30 V / 240 VA dual secondary transformers and no clue. What regulator is recommended? All I found is the LM317HV, but it doesnt give enough current ...
Dont want to spend so much for transformers anymore.
Thanks.
Old 15th February 2007, 02:21 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Look on the LM317 datasheet for how to add pass transistors to boost current.
Given the cost and heatsinking required for this project, I would just build a simple fixed unregulated PSU from a 100VA 2x25V transformer. There's rarely any need to have any more voltage than this just for testing.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 15th February 2007, 02:36 PM   #3
Im amazed!
Thank you, richie00boy. But its not meant for testing only.
Old 15th February 2007, 02:40 PM   #4
Did it Himself
Well even more reason to build a simple fixed unregulated supply then. Just build it with the most voltage whatever circuit you anticipate to use in the future will take.
Old 15th February 2007, 02:59 PM   #5
blmn is offline blmn  Brazil
blmn's Avatar
Try LM338 (5A regulator). It must be enough.
[url]http://www.datasheet4u.com/html/L/M/3/LM338_STMicroelectronics.pdf.html
Best regards,
Old 15th February 2007, 03:13 PM   #6
R.I.P.
an advantage of a regulated supply is flexibility for testing prototype circuits.
I see the main advantage as adjustable current limit.
For power amp duty, stay with unregulated.
regards Andrew T.
Old 15th February 2007, 03:17 PM   #7
Im amazed!
@ blmn: Vout of LM338 is 32 V max. ...
@ richie00boy: And whats about lower voltages then? For example a LM3875 with 4 load is ~25 V. A MyRev takes ~34 V. A Sysmasym ~36 V. And so on ...
In the future I dont want to burn money for all the transformers, thats in the back of my mind.
Old 15th February 2007, 03:20 PM   #8
Did it Himself
Just build a 25V supply then. The other amps will still work perfectly fine with this voltage.
The heatsinking cost, size and messing about building a powerful enough regulated supply might as well be spent on a new unregulated PSU for each amp as you need it.
Old 15th February 2007, 03:31 PM   #9
valveitude is offline valveitude  United States
valveitude's Avatar
Put a 10V zener from the "Adjust" pin to ground. This will float the reg., making it 11.2-42V instead of 1.2-32V.
-Casey
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
Old 15th February 2007, 03:32 PM   #10
blmn's Avatar
No,
VDiff for LM338 is 35V, If properly designed, fits OK for your needs.
It must be a problem in case of short-circuits, but, since you dont need less than 25V, you can pre-regulate or drop the voltage to achieve what you want.
But, for linear power supplies, is not a easy task achieve well regulated 40V from more or less 43 volts. The transformer must be very good. For this level of voltage I sugest you work in non regulated mode. A switch to bypass the regulator could work.
Best regards,
Advice wanted - regulated PSU for Vin 42 V / Vout 25-40 VHide this!Advertise here!
Balanced jfet buffer for Vout DAC? jonners Solid State 7 22nd October 2010 07:57 AM
where to connect + wire for Vout? jarthel Power Supplies 2 27th March 2007 04:49 AM
500W, PFC, isolated, regulated PSU advice theChris Power Supplies 3 2nd February 2007 04:19 PM
Advice wanted bret Planars & Exotics 14 3rd August 2005 03:34 PM
Wanted: Eagle advice pinkmouse Everything Else 9 25th February 2005 03:03 PM
