Dual Power Supply Design for LM4780
Old 10th February 2007, 04:15 AM   #1
yusuf is offline yusuf  India
Send a message via Yahoo to yusuf
Default Dual Power Supply Design for LM4780
I was looking at audiosector PSU for LM4780 and wondering why dual bridge rectifier with dual secondary transformer is used. Does it have any advantage over FWCT configuration which requires half the diodes and center tap transformer which is easier to obtain compared to two secondaries transformer.
I am refering to this: http://www.audiosector.com/lm4780%20psu.pdf
Old 10th February 2007, 01:14 PM   #2
jackinnj is offline jackinnj  United States
jackinnj's Avatar
National used 2 transformers in their LM4702 amplifier application note -- (AN-1490) they are smaller, (not smaller by volume than one transformer with the same VA rating), but perhaps more easy to configure in the chassis -- further -- they shielded the transformers with Mu-Metal.
At one time several DIYAUDIO participants were recommending regulating the power supply for the chipamps -- while the PSRR of the devices was more than sufficient it was thought that regulation improved the performance -- these designs were based upon a conventional off-the-shelf, positive-side-only regulator so 2 transformers or a transformer with dual secondaries was necessary.
Old 10th February 2007, 04:15 PM   #3
Thanks jack. I understand National's consideration for two smaller transformer. However, I am not able to follow your point on regulator. Any two regulator could be used with common ground, it really does not require two secondaries. or am I missing something.
Morever, I was comparing dual secondaries with bridge vs FWCT.
Old 11th February 2007, 09:59 AM   #4
R.I.P.
centre tapped can produce a dual polarity DC supply. The regulators MUST be +ve type for the +ve rail and -ve type for the -ve rail.
Dual secondaries can produce either a dual polarity supply with a common 0Volt and follow the centre tapped topology.
or
give two independant DC supplies which can each be regulated with any combination of +ve or -ve regulators.
Then the resulting pair DC outputs can be connected to form a dual polarity supply.
regards Andrew T.
Old 11th February 2007, 12:56 PM   #5
jackinnj's Avatar
Like so -- with the appropriate resistor values for your app:
Dual Power Supply Design for LM4780Hide this!Advertise here!
Need dual swithcing power supply design david maurer Power Supplies 0 23rd February 2007 03:54 AM
Dual LM4780 Kit Supply Question Dxvideo Chip Amps 9 8th September 2006 10:52 AM
help power supply LM4780 opik Chip Amps 5 12th November 2005 12:20 AM
LM4780 power supply merlinx76 Chip Amps 9 24th September 2005 10:34 PM
Dual LM4780 BPA-200 ExpressPCB.com Design. Opinions? los_ren Chip Amps 16 8th February 2005 05:53 PM
