Go Back   Home > Forums > Amplifiers > Power Supplies
Old 3rd February 2007, 09:28 PM   #1
wildswan's Avatar
Lightbulb Hey guys, any opinions on this tube supply?
I am designing a supply for a tube preamp (A few old skool passive EQ stages). It will be fairly high gain (To make up for the EQ losses) so I'll need low ripple above all else. I'll be putting it in a 1u 19" rack, so space is an issue.
The heater supply has to run off a 6.3v winding, hence the shottkey diode and half wave setup. As you can see ripple is taken care of by a pair of capacitance multipliers. (Which also supply a slow turn effect)
The plan is to put the rectifiers in a shielded compartment, and the 'regulators' in the main compartment to minimise hum.
Just wanted to get some opinions before I build anything....
Also, anyone got any suggestions for a better HV mosfet than the IRF820?
Old 3rd February 2007, 09:43 PM   #2
316a is offline 316a  England
316a's Avatar
Hi ,
The 0.47uF bypass cap should really go at the gyrator input . I used to use darlington pairs of TIP50 rather than mosfets in gyrators , used to get the odd f.u.c.t (failed under constant test) mosfet every now and again . Is that a half-wave rectified PSU on the heaters ? If so I'd get rid of that and use a bridge
cheers
316a
Old 3rd February 2007, 10:15 PM   #3
wildswan's Avatar
Hi 316,
Yep the darlington is a much better idea. I was going to use the mosfet because I thought they were more rugged in this setup. But if BJT's are ok here I'd definately prefer to use them.
I only have 6.3v ac at the heater winding of the transformer so I need a very low drop across the rectifier. I'm using indirectly heated tubes, so I figured a small amount of lower order ripple won't hurt. The gyrator is supposed to take care of all the higher order stuff. Am I being unrealistic?
Thanks,
WS
Old 3rd February 2007, 10:25 PM   #4
316a's Avatar
Hi ,
You should really use another transformer Either that or connect a pair of diodes as a voltage doubler . I don't like the idea of half wave rectified anything , unless it's only got an LED on the end of it
cheers
Old 3rd February 2007, 10:50 PM   #5
wildswan's Avatar
I know. But I like this Tx (It's a cute little toroid that fits in my case!) With a voltage doubler I'll waste more power. Oh btw the heater winding is only rated at 2.5A, and I'll probably use 2A of heater current eventually if I can. (I wanna see how many 6sn7s I can fit in ) Surely the doubler will also give me lots of ripple anyway?
A tube heater is a bit like a vintage LED
Is it worth a try?
Pentode guys: important to decouple g2 supply between stages? leadbelly Tubes / Valves 4 27th September 2008 05:12 AM
Need you guys to look at this on you tube skooter Car Audio 2 28th November 2007 04:45 AM
LITE DAC 60 tube opinions? inertial Digital Source 2 8th February 2006 08:11 AM
tube preamp...opinions trancy Tubes / Valves 31 2nd March 2004 02:03 AM
Hi guys, What tube amp projects are there for around $100 or less? NathanP Tubes / Valves 4 21st May 2002 05:53 PM
Page generated in 0.08699 seconds (74.65% PHP - 25.35% MySQL) with 11 queries
