Center-tap to ground? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th January 2007, 04:41 PM   #1
Default Center-tap to ground?
I finally got my Aikido hum down to tolerable levels, after much advice from folk on the Tubes forum.
Now, my question relates to the center-tap of my Hammond 269AX 125-0-125 transformer. I am using full-wave recitification and get around 360VDC after the cap input filter system. My heaters are powered by a separate 6.3VAC transformer whose center-tap is referenced to 1/4 B+.
So, back to the HT transformer. Do I need to ground the center-tap? If I do, where's best? I could connect it to the ground of the recitified voltage, in other words, I'd connect it to the -ve end of the first cap (a 1.5uF motor-run). Or, I could connect it directly to the chassis.
Right now, my PSU/signal grounds are run into the Broskie Aikido board utilizing the star-ground on the PCB. The PCB is direct coupled to the chassis using the designed-in PCB mounting bolt. I will experiment with this a little to see if diode/cap/resistor combination can lift this ground a little from the chassis/IEC earth.
I would appreciate any help on this.
Charlie
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 4 18th March 2014 10:42 PM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 04:50 PM
Center-tap to ground? cbutterworth Tubes / Valves 3 17th January 2007 10:18 PM
Center to Center of Drivers 29" apart in proposed config - Problems?? Ken L Multi-Way 14 3rd November 2003 01:49 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 01:55 PM
Copyright 1999-2017 diyAudio
