lm317 LM337 PCB file wanted - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th January 2007, 08:24 AM   #1
Nordic is offline Nordic  South Africa
Nordic's Avatar
Default lm317 LM337 PCB file wanted
Hi, I'm looking for eagle files for and adjustable lm317/337 power supply... I built one last night but the positive rail is wacky....
I can basicaly get 4V out of it, and if I turn the pot any further it jumps to the full 28V input voltage...
Old 14th January 2007, 09:34 AM   #2
I had the same problem only with LM317 variable power supply...
Check if the pot is OK... I hah damaged pot...
There is also good to put 1/2W pot
Greeting,
Toni
Old 14th January 2007, 10:01 AM   #3
Nordic's Avatar
allready swapped pots, and regulator itself... will try to swap caps later.. or maybe start by removing all of them... and putting them back one at a time...
WOULD REALY APPRECIATE A PCB FILE !
Old 14th January 2007, 10:56 AM   #4
Nordic's Avatar
Ok, it must have been the pots... eventualy swapped with a 1W 3k3 resistor, and its pumping out 18.5V now, which I can live with... target was 15- 20 volt...
Old 14th January 2007, 12:28 PM   #5
perhaps this can help you
http://orca.st.usm.edu/~jmneal/dual_psu/psu2.pdf
Old 14th January 2007, 05:07 PM   #6
Nordic's Avatar
Thats pretty close to what I settled on...
Waiting for some better quality phillips caps from the UK... So I may still remove a few, but these have been added one at a time with proper listenig using headphones.... life would be so much better with a scope, but your ears are pretty usefull too...
Old 17th January 2007, 02:10 PM   #7
Hi Nordic,
you have omitted the decoupling caps on the regulator pins.
The circuit could oscillate without them and similar control problems may ensue.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th January 2007, 07:43 PM   #8
Minion is offline Minion  Canada
I use this PSU that deliver a regulated +/-15v and an Unregulated 26v (depending on the Transformer used)....
It has worked well for me .....
sorry if it looks a Bit sloppy...
Old 21st January 2007, 01:14 PM   #9
Default !
Maybe this will help?
Pa mislim sta reci!
Ce sa spun!
Another look at the LM317 and LM337 regulators jbau Power Supplies 333 8th October 2014 04:37 AM
LM317/LM337 accuracy Stuey Power Supplies 6 25th May 2007 09:31 AM
Copyright ©1999-2017 diyAudio
