Gate-source voltage needed to switch a FET
Old 8th January 2007, 06:27 PM   #1
rtarbell is offline rtarbell  United States
Default Gate-source voltage needed to switch a FET
According to most datasheets of powerFETS, the suggested gate-source voltage to switch a FET into full "ON" mode is at least 10V, while the max gate-source voltage is 20V (as listed under absolute maximum ratings).
==> Is there much of a difference between switching a FET using a gate-source voltage of 12V, as opposed to 15V, as opposed to 18V? I know the higher the Vgs, the faster the FET switches (and thus switch losses can be reduced), but is there a "law of diminishing return" here? I don't have much practical experience with switching FETs; I wanted to ask before I try anything dangerous...
Old 8th January 2007, 06:35 PM   #2
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
I would say a good Gate-Source voltage would be 15V. This way, no problems.
Old 8th January 2007, 06:36 PM   #3
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default Re: Gate-source voltage needed to switch a FET
The data sheet also shows you characteristics of Id vs. Vgs for a given Vds. You can see that the Vgs actually controls the Id. So, you really have to be sure you have enough gate drive for the expected Id you want to switch. Err on the plus side: too high Vgs doesn't harm (as long as you stay below the max; better use a zener shunt here!).
If the 10V Vgs is enough to turn it hard on, there's not much point in going higher. Going higher does NOT turn it on faster: it turns on faster if you can sink more current into the gate capacitance, so use a driver with (relatively) high currrent capacity, at 10 V.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 8th January 2007, 07:21 PM   #4
N-Channel's Avatar
Yeah, that's what I meant!
Old 8th January 2007, 08:21 PM   #5
jan.didden's Avatar
... but it's not what you said
Jan Didden
Old 8th January 2007, 08:43 PM   #6
batee is offline batee  United States
batee's Avatar
Default High Side FET drive...
Here's what I did for a FET switching in a motor control project, but it's pretty generic. Works for 0-100% PWM duty cycle.
http://www.diyaudio.com/forums/showt...81#post1088581
Old 8th January 2007, 09:28 PM   #7
batee's Avatar
Schematic and board here:
http://www.diyaudio.com/forums/showt...90#post1088590
Old 8th January 2007, 09:48 PM   #8
sawreyrw is offline sawreyrw  United States
A Vgs higher than 10 volts will turn the MOSFET on faster (with a given gate resistance) because the effective gate capacitance will be charged faster. However, it will take longer to discharge this same capacitance, so the total turn off time will be longer. In addition, the power to drive the gate will increase. All in all, it's best to use the vendors spec. which is typically 10 volts.
Old 8th January 2007, 11:25 PM   #9
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
A higher Vgs usually produces lower Rds (or lower Vce for IGBT) and thus lower conduction losses for any given current, however, the improvement is not always worth the effort or the risk of going near the 20V limit (datasheet has the last word on that). I routinely use 19V gate driver supplies in most of my circuits.
I use to feel like the small child in The Emperor's New Clothes tale
Old 9th January 2007, 10:27 AM   #10
VEC7OR is offline VEC7OR  Lithuania
VEC7OR's Avatar
Yes, and reduces useful life of fets, also you have to suck more charge out of gate.
IMO anything over 15V is overkill, but again depends on fets.
Profanity took a very interesting form in Russia where there exists a language of sorts, most of its words based on four basic profane roots - nouns p...is, wh.0.e, c..t and verb f..k. It is possible to sensibly communicate using just these four basic roots.
Gate-source voltage needed to switch a FETHide this!Advertise here!
FET Switch Isolation using optocouplers instead of conventional gate drivers rtarbell Power Supplies 8 4th February 2011 09:24 PM
mosfet gate voltage question carpenter Pass Labs 6 22nd July 2009 02:34 AM
Do I have to match voltage Gate-Source of mosfet in SMPS? Charoenchai Car Audio 5 17th November 2006 09:28 PM
MOSFET gate voltage xplod1236 Parts 17 4th December 2004 03:23 PM
best way to generate Gate-Drain or Gate-Source short in electret capsule JFET? capslock Parts 2 27th September 2002 08:07 AM
Copyright ©1999-2017 diyAudio
