diy balanced power unit question
Old 2nd January 2007, 11:51 PM   #1
NotoriousBIG_PJ is offline NotoriousBIG_PJ  Canada
Default diy balanced power unit question
<edited by mod>
Hi everyone,
Attached I have a diagram of my diy balanced power setup. I was wondering if my ground is wired in an optimum way, or if there are things I should change?
Also, would it be worth while sticking a emi/rfi power line filter between the 2 outlets to help isolate analogue from digital, and would I also attach the new filter to the same ground?
Thanks,
Biggie.
Old 2nd January 2007, 11:58 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Biggie, I have created a new thread for you.
After you search, click the "have you searched" button in the upper left. That will allow you to start a new thread.
planet10 needs your help:
Let's help Ruth and Dave
Old 3rd January 2007, 03:30 PM   #3
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Nope.
Term #1 & #4 to input High
Term #3 & #6 to input low
Term #8 & #10 to output high
Term #9 & #11 to output low
Term #7 to Case Ground
Socket Safety Ground to Case Ground
Kevin
Old 3rd January 2007, 07:12 PM   #4
moamps is offline moamps  Croatia
Default Re: diy balanced power unit question
Hi Biggie and welcome to the forums!
I built myself a couple of power conditioners using line filters and balanced transformers. It is my experience that an emi/rfi line filter on the secondary of a balanced transformer is not really necessary. For more details, you can check out my website with the completed projects (called Gridmox1 and Gridmox2). The text is in Croatian but the pictures are self-explanatory. Just holler if you need more specific info.
Milan
Old 3rd January 2007, 08:56 PM   #5
Thanks for the replies. ^^
Originally posted by Kevin Graf
Nope.
I'm not sure what you mean by input High, input low, output high and output low. Are they 4 seperate grounds?
Biggie.
Old 3rd January 2007, 11:28 PM   #6
You better be careful or you may hurt yourself and/or blow something up!
High = Hot, Black wire
Low = Neutral, White wire
Safety Ground = Green or Green/Yellow wire
The "Low" wires are Neutral not Ground!
In the primary the Neutral is connected at the house main circuit box to the Safety Ground.
In the isolated secondary the Neutral is not connected to the Safety Ground in any way.
Oh WAIT - - THIS IS A BALANCED SECONDARY NOT AN ISOLATED SECONDARY !!!
Do it this way:
Term #1 to input Hi
Jumper Term #3 to Term #4
Term #6 to input Low
Term #7 to Case Ground and input Safety Ground
Term #8 to output High
Term #11 to output Low
Jumper Term #9 to Term #10 then to:
Socket Safety Ground then to:
Kevin
Old 3rd January 2007, 11:40 PM   #7
Looking at your drawing again.
The Secondary wiring is OK.
But if all four windings are 115/120 Volt.
Wiring the Primaries in parallel and the Secondaries in series.
Will OUTPUT 240 VOLTS.
Kevin
Old 3rd January 2007, 11:54 PM   #8
Just to clarify, I've had this conditioner running for over a year and a half. I did the grounding based on this Jon Risch quote:
"If a technical ground as described in the equi=tech article is not constructed according to the proper method and connections, then the original AC ground should be used for all the grounds."
And the "case ground" in my diagram is just a large screw inside of the case, attached to the bottom that was used as the ground for the unbalanced oneac conditioner that used to be in the case. I think I'm using the wrong terminology for it.
Biggie.
Old 3rd January 2007, 11:54 PM   #9
I'm getting 60/60 reading from the outlets.
Biggie.
Old 3rd January 2007, 11:54 PM   #10
Do it this way:
Term #1 to input Hi
Can you explain the difference between case ground, input safety ground and socket safety ground?
Thanks,
Biggie.
diy balanced power unit questionHide this!Advertise here!
DIY balanced power unit with dual 60v secondary transformer? bikehorn Power Supplies 5 8th February 2008 06:59 PM
Please help! Isolation/balanced power question. jborum Power Supplies 15 3rd July 2007 05:51 PM
Balanced ac power question John C Power Supplies 1 5th November 2006 11:54 AM
Balanced power fuse question ftjandra Parts 1 30th June 2004 08:56 AM
Power supply unit question Ilianh Pass Labs 22 28th October 2002 08:27 AM
