Go Back   Home > Forums > Amplifiers > Power Supplies
Old 1st November 2008, 03:42 PM   #181
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
Originally posted by N-Channel
As for flux-wlking, see post #74, this thread. As opposite phase is energized, any flux remaining in the core is canceled out.
Flux "cancellation" only happens if the volt-second/turn product of the opposite phase equals that of the first phase - ie. perfect duty cycle balance. Your design doesn't guarantee that.
During deadtime, the transformer may reset itself through the MOSFET body diodes or something. I'll have to simulate this thing and find out.
Old 23rd April 2010, 07:26 AM   #182
gev is offline gev  Turkey
gev's Avatar
12v=19v 4,7A dcdc circuit schema and pcb new download link: 4shared.com - online file sharing and storage - download uc3843-19volt-dcdc.zip pcb 12-19V 95W-DCDC UC3843 .LAY open sprint layout viewer http://www.abacom-online.de/html/dat...ewlayout50.exe
320volt.com Elektronik ve biraz daha fazlası
Old 23rd April 2010, 11:56 AM   #183
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
looks good, a bit big, but depends for what you use it for
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 25th June 2010, 04:28 PM   #184
hi
i'm so sry,but i have to know it!
what is F1 in the list?
(F1=8A)
so sorry.thanks
Old 25th June 2010, 06:19 PM   #185
star882 is offline star882  United States
star882's Avatar
That's a fuse.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 27th June 2010, 07:25 PM   #186
hi
does any IC Similar UC3843 for this kit?
i need another IC because i can't find this one!
thanks
Old 27th June 2010, 08:00 PM   #187
star882's Avatar
Originally Posted by bmx666 View Post
hi
thanks
Try the LT1247.
Old 27th June 2010, 08:34 PM   #188
Originally Posted by star882 View Post
Try the LT1247.
sry
and for diod ( MBR1645)?
Old 27th June 2010, 10:02 PM   #189
Send a message via Yahoo to Th3 uN1Qu3
Okay i've only read the first pages, but i do have a question. I couldn't believe that the inductor is wound on that yellow core but it appears to be so. 19 volts at 4.7A is quite darn close to 100 watts, are you serious that the little powdered iron donut works at that power? I have dozens of those around and they're quite a bit easier to work with than EE/EI cores, at least for my hands that is.
I'm planning to run in discontinuous mode too, using pulse skipping as the control method. You'll be surprised as to what my controller chip will be. Next week i'll be building the first low-power version and if all is well i'll try a larger one.
Old 29th October 2011, 09:42 PM   #190
Originally Posted by gev View Post
Transformer EI33 --10x0.5mm prallel 20 tour
PCB view and print program
Download
PCB SCHDownload
hi, why i am unable to download PCB SCH file.
can you pls provide good link for the same, i also visited your site, as its not in English, i couldnot find it there too.
pls provide link for the same.
regards
EDIT:- I got the File from 4shared Link. Thanks
BTW is this circuit from Electronics For You
core power ratings for 9kW DCDC stuartsjg Power Supplies 36 19th July 2008 09:57 PM
StepUp dcdc smps (car amp) gev Power Supplies 3 7th May 2007 06:40 AM
Page generated in 0.10831 seconds (76.42% PHP - 23.58% MySQL) with 11 queries
