12v=19v 4,7A dcdc
12v=19v 4,7A dcdc
Old 13th July 2007, 05:55 PM   #101
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
If you're talking about the 2-F boost converter, look at post #35, this thread.
Old 13th July 2007, 06:05 PM   #102
luka is offline luka  Slovenia
luka's Avatar
12v=19v 4,7A dcdc
Hi
What that...how did I miss that. Anyway thanks. Maybe you can tell why did you use what switch, what voltages do you get?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 13th July 2007, 06:26 PM   #103
N-Channel's Avatar
I chose the MTP75N06 because it has only 9mW Rds(on), can pass 75A thru its drain, and I had alot of them lying around. I also had the SMT version of them, if I wanted to downsize the circuit.
When switch S1 is closed, V(out) is ~16V, and when it is open, V(out) is ~20V. Guy I did it for needed compatibility with both his laptops.
Old 7th August 2007, 06:21 PM   #104
jamesrnz is offline jamesrnz  United States
jamesrnz's Avatar
so i am trying to get rid of huge spikes at turn off on kampenens,
i have rewound the transformer and am using 216 of number 36 for my windings?
jimbo
Old 8th August 2007, 04:44 AM   #105
N-Channel's Avatar
Let me see if I understand this right: You're using 216 strands of #36 AWG wire? OK, That should do fine (I assume this is your version of Litz wire?)
Not sure why you're getting huge turn-off spikes. Might want to check your leakage inductance, this is usually the cause.
Old 8th August 2007, 11:09 PM   #106
jamesrnz's Avatar
this is some wire i got from space junk in orlando.
it is already sort of twisted slightly.
i have it on a large e-e core.
i have to look closer when i get back in town.
thanks
Old 20th August 2007, 04:03 PM   #107
jamesrnz's Avatar
Default turnoff spike
sooo i am using schottkies for the mosfet protection and schottkies for the rectifiers on the secondary.
should i be using ultra fast or fast recovery types? i am operating around 150khz......
Old 30th August 2007, 01:05 AM   #108
N-Channel's Avatar
Schottkys should be fine, especially for the output rectifiers because of their lower forward voltage drop (very important for high-current outputs). A while ago, I found some Schottkys with a 200PIV rating. A couple of years ago, I had heard of some 600V Schottkys, but nothing since.
Old 31st August 2007, 03:09 AM   #109
jamesrnz's Avatar
i think i have too many turns on the transformer. i am going to recalculate and see if i can get that pesky spike down to an acceptable level.
i was looking at maybe adding a lossless snubber........
Old 1st September 2007, 05:40 PM   #110
N-Channel's Avatar
Couple o' threads on that subject going on right now. Less turns to get rid of the spike might sound like a good idea. I would look at either Brown, Chryssis, or one of the NSC or ONSemi App Notes.
12v=19v 4,7A dcdcHide this!Advertise here!
core power ratings for 9kW DCDC stuartsjg Power Supplies 36 19th July 2008 08:57 PM
StepUp dcdc smps (car amp) gev Power Supplies 3 7th May 2007 05:40 AM
