13.8V 10A Smps [Test ok]
Old 24th December 2006, 11:20 AM   #1
gev is offline gev  Turkey
gev's Avatar
Default 13.8V 10A Smps [Test ok]
All Transpormer Pc Powersupply
pcb-sch Download
Old 24th December 2006, 11:41 AM   #2
edl is offline edl  Hungary
edl's Avatar
PCB in PDF format.
Old 24th December 2006, 11:43 AM   #3
edl's Avatar
Parts on PCB in PDF format.
Old 24th December 2006, 12:16 PM   #4
gev's Avatar
tanks edl
pbc view and print program
SprintLayout-Viewer Download
Old 24th December 2006, 12:55 PM   #5
luka is offline luka  Slovenia
luka's Avatar
Have you builded and tested it?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 24th December 2006, 01:04 PM   #6
mitwrong is offline mitwrong  China
mitwrong's Avatar
Send a message via AIM to mitwrong Send a message via MSN to mitwrong Send a message via Yahoo to mitwrong
Default Re: 13.8V 10A Smps [Test ok]
pcb-sch Download
Hey, What's the argument???
Good Luck!
Old 24th December 2006, 01:12 PM   #7
luka's Avatar
Now I see the pictures finally. Seems to be working , Great work. What is its max power,even if some changes were needed?
Feedback is doing its job, could I see some output scope picture under heavy load?
I FEEL SLOVENIA
Old 24th December 2006, 02:00 PM   #8
edl's Avatar
It performs well with AT/ATX PC-PSU's main and driver transformer. They are cheap and available.
Old 24th December 2006, 02:06 PM   #9
luka's Avatar
How is main trafo winded, turn-ratio?
I FEEL SLOVENIA
Old 25th December 2006, 03:58 AM   #10
mitwrong's Avatar
Luka:
The calculation to wind a pwr transformer is complicated, you have to know the lamination magnetic flux, otherwise take this simple equation.
volt per turn = winding cross section X K.
winding cross section = the centre E of the lamination W X L.
K is constant, depends on the quality of the lamination, usually is 9.00. for general quality. If higher, use 8 or 7. Try to flip a piece of lamination, see how many flips till it breaks, if 3 times, take K=7, if 5-6 flips, take K=8, the rest take K=9.
eg. pri = 220V, sec = 24v2A
Therefore: pri = 220 X 9 = 1980T
sec = 24 X 9 = 216T
220V at 48 watts + 2% eff lost = 50W.
Check from wire gauge table on 220v = 0.218A = ? AWG
24V = 2A = ? AWG
The input + loss make it .22A
Select the wire from the gauge stated, and start your winding.
Good Luck.
13.8V 10A Smps [Test ok]Hide this!Advertise here!
Is there any test cd to test jitter using a scope ? gaetan8888 Digital Source 4 10th August 2007 09:24 AM
PC PSU test nicoch58 Power Supplies 0 22nd November 2006 07:16 PM
test Ilianh The Lounge 0 10th August 2003 05:25 PM
