diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   Very basic: 22V to 12V AC (http://www.diyaudio.com/forums/power-supplies/91472-basic-22v-12v-ac.html)
Mr.Mekulic 2nd December 2006 08:10 PM
Excuse the noob question :cannotbe:
I have a 350VA 22-0-22 trafo for my amp, but I need a 12V 1A supply for the input select and motorized pot circuit.
What is the easiest way to get 12V from 22V AC?
moamps 2nd December 2006 09:00 PM
Hi:
You can use an LM338 voltage regulator to reduce the voltage from the rectifier capacitors of the output amplifier to 12V DC. You may need to add a heatsink to the regulator. The schematic is here:
http://www.national.com/pf/LM/LM338.html
Milan
Mr.Mekulic 2nd December 2006 09:07 PM
Originally posted by moamps
Hi:
Milan
Thanks for the reply but I need to get 12V AC from 22V AC.
moamps 2nd December 2006 09:12 PM
Motorized pot circuits must be powered with DC. Things will be much clearer when you post a picture or the schematic.
Milan
Mr.Mekulic 2nd December 2006 09:26 PM
Milan
This one has PS on board, I just need 12V AC to run it :D
This what I ordered:
http://eshop.diyclub.biz/product_inf...roducts_id=247
they say it needs 12V 1A trafo
moamps 2nd December 2006 09:46 PM
The picture in the link you have provided shows an onboard power supply, made of the rectifier, capacitor (the big blue thing) and regulator (mounted on a heatsink). As I said earlier, you should use an LM338 to build a voltage drop regulator. The +output of the LM338 regulator must be connected to the +pin (plus) of the big blue capacitor whereas the -output of the LM338 (ground) must be connected to the -pin (minus) of the blue capacitor. This is the simplest way to do it. Otherwise, you would have to use a non-standard transformer to reduce 22V to 12V AC, which complicates things considerably.
Milan
paulb 2nd December 2006 10:06 PM
I would use an LM7812 (or LM340T12) as it is simpler to use and much cheaper than the LM338. The motorized pot does not draw very much current.
http://www.national.com/pf/LM/LM140.html
moamps 2nd December 2006 10:13 PM
Yes, the question is how much current is drawn by the entire circuit (including the pot and relays). If it's not too much, paulb has a point.
Milan
Mr.Mekulic 2nd December 2006 10:39 PM
2 Attachment(s)
Milan
Ok I think I got it. Please check if i got the resistor values right.
As I see you are from Croatia, LM338 is expensive could you suggest a replacement from Chipoteka :D
Is LM350T ok ?
moamps 2nd December 2006 10:51 PM
The resistors are OK.
You may replace the LM338 with 7812CT TO3 or 7815CT TO3 (2 EUR in Chipoteka) if you wish BUT then you would have to use a different schematic!
Milan
EDIT: Yes, LM350T is also fine.
Resources saved on this page: MySQL 18.75%
