Very basic: 22V to 12V AC - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 3rd December 2006, 02:37 PM   #21
moamps is offline moamps  Croatia
Originally posted by Mr.Mekulic
Do I need to check anything else ?
Make sure you also check the temperature of the regulator. Keep us posted.
Milan
Old 11th December 2006, 09:23 AM   #22
Can't u use half wave rectified 22V. U will keep the heat low this way.
Gajanan Phadte
Old 22nd December 2006, 05:53 PM   #23
DJ Exprice's Avatar
Send a message via AIM to DJ Exprice Send a message via MSN to DJ Exprice
Milan
Exactly. The LM7812 gets very, VERY hot if enough current is being drawn and/or if the input voltage is anything above 18v! Put a heatsink on that hummer and it'll SHINE!
It'll run very well with even a tiny heatsink. The variable regulators can get hot, but not as hot as the standard ones. The variable regulators have a 5A output and the LM78/s/xx/LM9/s/sxx (the standard ones) only have about 1-1.5A output! How do you figure that?
I would still go with either no regulator and just do what the kit says, or run it through a POSITIVE variable regulator (and a NEGATIVE variable regulator if you need to have the +/- balance perfected )
DIY basic Solve Multi-Way 1 3rd October 2006 10:09 PM
Amp6 Basic Dennis Hui Class D 10 27th September 2006 02:27 AM
Help with Subs and Amp (basic) Sedodes Car Audio 5 3rd January 2006 12:08 PM
A basic chipamp in a not so basic case. waltson Chip Amps 19 24th August 2005 07:40 AM
Zen (basic) and BoZ PCB ThierryM Pass Labs 0 23rd October 2003 06:57 PM
Copyright 1999-2017 diyAudio
