#31 |
It's not exactly clear what your concern is. I need to ground the primary side to the secondary side? I wouldn't think so. If not, what are you suggesting?
#32 | |
The difference in sensitivity depends on the rating of the device. Mine is 30mA, model ABB DS202C. Thanks |
#33 |
Hello all, two points to highlight:
1. this is a balanced output 2. the tx is shielded and isolated with balanced output (115 - 0 - 115) Since the tx is already filtering DC is it really necessary so much additional filtering, and if so, for what devices? My amps on commercial power conditioners/filters sound worse, any ideas why? |
#34 |
I think that I would use the RCBO as the very first thing on the primary side as a multifunction device.
It's not as ugly as US GFCI breakers.
Kevin |
#35 | |
If it is earth, as in the concrete you are standing on, you will die if you hold the L and stand on the same concrete. And it won't trip the RCD on the primary side. |
#36 | |
The diagram is incorrect and now I will amend it for the next version. In this case the yellow/green wire since this is arriving from a standard plug. If the earth stays constant from building to primary it will trip the RCD, and, on both sides because they are mechanically coupled to each other. However, I'm not sure how I will connect this on the transformer (in arrival in the next couple of days) since there will also be a shield to contemplate. Thanks! |
| RF mains filter box | ash_dac | Power Supplies | 5 | 26th January 2007 09:26 AM |
| Mains filter QS | Bassivus | Parts | 7 | 19th September 2006 07:12 AM |
| DIY Mains Cleaner/Filter | dynoPort | Parts | 3 | 23rd November 2004 12:59 PM |
| mains filter? | karma | Solid State | 1 | 14th June 2004 04:10 PM |
| mains RF filter | habana | Analogue Source | 3 | 21st October 2003 11:37 PM |
| Page generated in 0.08113 seconds (82.93% PHP - 17.07% MySQL) with 11 queries |
