Go Back   Home > Forums > Amplifiers > Power Supplies
Old 30th November 2006, 02:02 AM   #1
Stasiu is offline Stasiu  United States
Default Newb question...Center pot'ed transformer and rectifiers
I've been lurking about this web site for months, learning here and there, and thinking up more projects than I have the time or money to do. The main area of interest of mine on this site is the DIY amplifier section. My goal is to eventually put together some type of class A amp (Aleph, Krell clone, etc.).
My question today is about an old Realistic STA-2100 amp that I inherited from an uncle years ago. I've stripped it down to it's PSU and dual amp PCB's and am hoping to bypass the whole pre-amp section. The plan was to rebuild the PSU with separate full wave rectifiers and a bank of 30,000 uF caps (currently 15,000 uF per side) for each channel and and make it a dual mono block after the toroid, but I just realized it has a center pot'ed torroid. Is it possible to wire two full wave rectifiers for each channel? Could I wire the secondaries from the transformer to the AC diodes of the rectifier in parallel and wire the 0v common wire of the torroid in parralel between the capacitors that need to be in series per side?
Old 30th November 2006, 06:07 PM   #2
Hi Stasiu
I would like to help, but your description is a little fussy
If you could post a sketch of what you want to do, I think that will help us understand more clearly.
Old 30th November 2006, 07:19 PM   #3
I'm actually working on a schematic right now....just have to download some software.
Old 30th November 2006, 08:18 PM   #4
I drew this up in eagle. Does any of it make sence?
Old 1st December 2006, 12:50 AM   #5
any thoughts?
Old 1st December 2006, 01:17 AM   #6
If you have a center-tapped transformer, you should probably only use a single rectifier. There's numerous threads in the chip amps section about wiring up single versus dual rectifiers on center tapped an dual secondary transformers.
Old 1st December 2006, 06:28 AM   #7
I understand how to wire one rectifier to a center pot'ed transformer, but will what i posted work? I've read on these forums that having two rectifiers will help stabalize the + and - DC lines and would like to hear the difference for myself. I'd like to separate the power supply to the separate sides as much as possible.
Old 1st December 2006, 09:18 AM   #8
As far as I know, it will not work. In order to use double rectifiers, you need two completely separate windings. I believe that in itself is part of the improvement that you get when going that route.
Old 1st December 2006, 10:43 AM   #9
pinkmouse's Avatar
The only way this will work is if you can get into your transformer to split the centre tap. Dual rectifiers will not work at all with a single centre tap.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 1st December 2006, 06:42 PM   #10
Thanks for the help
Transformer wiring question, series, parallel and center tapped swin1 Power Supplies 12 7th November 2008 07:58 PM
Two Rectifiers, One transformer jkeny Tubes / Valves 9 1st August 2008 04:15 PM
newb center channel v1d9uy Full Range 15 12th January 2006 10:07 PM
Very newb question jaws2421 Solid State 7 29th December 2005 05:46 PM
two rectifiers one transformer? homer09 Chip Amps 8 24th January 2005 06:01 PM
Copyright ©1999-2013 diyAudio
