Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th November 2006, 11:05 PM   #11
pinkmouse's Avatar
And a view from the top looking towards the traffo:
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 26th November 2006, 11:06 PM   #12
jleaman is offline jleaman  Canada
Send a message via AIM to jleaman Send a message via MSN to jleaman Send a message via Skype™ to jleaman
pinkmouse,
You Got Mail.!
Old 26th November 2006, 11:19 PM   #13
pinkmouse's Avatar
Thanks Jason, but the problem is not with that board, I just need to get high frequency 24V ac into it, normally provided by the huge iMac PVB, (power and video board, but don't let the video bit distract you, it means CRT driver stuff).
Al
Old 27th November 2006, 03:11 PM   #14
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Hi pinkmouse, can you provide a better quality version of the picture from post 9? The dirt and the fact that it's out of focus is preventing me to see most of the tracks. It may not be 24V HF as you think.
I use to feel like the small child in The Emperor's New Clothes tale
Old 27th November 2006, 03:27 PM   #15
pinkmouse's Avatar
Eva, dusted as requested!
I've ordered an ATX psu from ebay, it was ony a fiver so I do have a fallback plan, but I would still really like to get this working. It would be so much more compact.
Al
Old 27th November 2006, 04:01 PM   #16
Eva's Avatar
Well, it seems that they use a linear regulator for the 12V output and magnetic amplifiers for the 5V and 3.3V outputs. The transformer is then fed with high frequency AC so you were right. The AC waveform may be either unipolar (switching in one direction for 50% of time and allowing the transformer to demagnetise for the other 50% of time) or bipolar (produced by a full bridge). The frequency also remains unknown, you would have to do some bench tests in order to know how long it takes to saturate and derive a suitable frequency.
Do you still have the circuit that provided the 24V AC? A quick look at the topology would already tell me if it's unipolar or bipolar.
Old 27th November 2006, 06:31 PM   #17
pinkmouse's Avatar
Thanks for all your assistance Eva.
Ok, here is the main power board. The connector where the 24V comes out is indicated by the yellow arrow. The stuff that isn't in the pic is the CRT stuff - flyback traffo etc.
Al
Old 27th November 2006, 06:33 PM   #18
pinkmouse's Avatar
And the underside, connector again marked, as is the extent of the 240V circuitry.
Al
Old 27th November 2006, 06:37 PM   #19
Eva's Avatar
Great, this one looks like a big off-line flyback. Can you take a couple of clear pictures of the bottom side of the board? The interesting portion goes from the big heatsink to the small heatsink (including it) and the edge of the square hole.
They may be slaving the other transformer to the flyback and attaching the primary of the other transformer directly to the secondary of the flyback.
Oh, and try to read the model of the big swithcing IC in the big heatsink, it will probably tell us the switching frequency.
Old 27th November 2006, 07:02 PM   #20
pinkmouse's Avatar
Good job I put the batteries on charge!
Ok, here is the bottom immediately under the traffo, heatsink is towards the top:
Al
New iMac with OSX 10.5.2 and iTunes - Thoughts? hifimaker Digital Source 25 26th May 2008 06:33 PM
iMac & XP SP3 rabbitz Everything Else 0 8th May 2008 04:41 PM
Harmon-Kardon iMac iSub for Home Theater ooops! Subwoofers 1 1st October 2007 03:09 AM
SMPS & SS amp happyears Power Supplies 7 31st July 2007 10:25 AM
Page generated in 0.11293 seconds (82.03% PHP - 17.97% MySQL) with 11 queries
