Rewire Toroidal from 110v to 220v - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th November 2006, 07:57 PM   #1
Default Rewire Toroidal from 110v to 220v
Hi
Im trying to rewire a Presonus ADL 600 from 110v to 220v. I know the primary/secondary have to be in serial, but Im not sure on the exact setup of this transformer, so Im a bit lost.
Wire colors are white / black / Yellow / Orange
There is an 8ohm resistance between yellow/orange AND also between Black/white.
With black/white tied together (shorted) - the resistance between yellow/orange is 14ohm
Photos of wiring here:
http://img399.imageshack.us/img399/9...g4365ccpw8.jpg
Can anyone help me out with the procedure on this.
Old 10th November 2006, 08:12 PM   #2
Did it Himself
richie00boy's Avatar
The white-black winding is one half of the primary and the yellow-orange winding is the other half. You need to find out which is the start and which is the finish of each of these windings to ensure you connect them in correct phase.
Based on the above, I would expect that if you connected any of the following you would yield 16 ohms:
white-yellow
white-orange
black-yellow
black-orange
It's very strange that if you shorted one winding you got 14 ohms.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 10th November 2006, 09:11 PM   #3
How do I find out which wire is the start of the winding ?
I actually got the amp to run with the black/white shorted and yellow/orange connected as before. That config gave me 110v on secondary.
Ive also tried shorting the yellow/orange, that gave me 220v on the secondary, but (close to) 0v on the pcb board outputs, so Im guessing that was out of phase. (amp did not run)
Im now going to do a real world test on the amp to see if there are any audio artifacts etc - and Ill report back.
Old 10th November 2006, 09:41 PM   #4
do you have on hand a second tranfoo with a low voltage at output it could be usefull to make a few test?
Old 11th November 2006, 02:29 AM   #5
"do you have on hand a second tranfoo with a low voltage at output"
I have two identical transformers, one of them is still untouched - so i can use it as reference.
Ill be going through several pieces of 110v gear that I need to convert, so I really need to get these things figured out. There really needs to be a wiki dedicated to 110v <> 220v conversions.
Can anyone point me towards some info on how to find the primary/secondary - winding start/finish.
Would really appreciate all info and help
Old 11th November 2006, 09:23 AM   #6
Did it Himself
Sorry but you don't appear to know what you are doing and I suggest you take it to somebody who does before you blow something up or kill yourself.
You should not be seeing 220v on the *secondary* - I'm assuming you are on about playing with an existing transformer inside the amp?
Old 11th November 2006, 03:02 PM   #7
rewireyour tranfo as shown below ( dont forget to use low voltage supply anythimh from 5 to 60 volts will do ).
measure voltage between yellow & orange should be equual to your supply.
measure voltage between white & black should be equual to your supply.
measure voltage between black & orange must be twice your supply.
if twice your ok, if not reverse white & black and test again
measure voltage between white & orange must be twice your supply.
Old 11th November 2006, 03:18 PM   #8
"Sorry but you don't appear to know what you are doing"
- that is true
"I suggest you take it to somebody who does before you blow something up or kill yourself."
- well, I should have - but I figured this out and the amp is running smoothly now. Now I just need to learn some more before I attempt something similar again.
Is there any universal wire color coding spec for these toroid trans that would indicate the first winding start/end - and the second winding start/end?
...and sorry to bother you guys with my ignorance - I am just starting to figure this out
Old 11th November 2006, 03:58 PM   #9
build or get someone to build for you a Mains Light Bulb Tester.
The idea is that you plug in the mains light bulb in series with the unit to be tested.
If there is a wiring fault then then bulb lights up and drops almost all the mains voltage safely.
The little voltage and current that remains passes safety throught the equipment without causing major damage or blowing anything up.
It works especially well when trying to fathom out the phases of a twin primary transformer.
Do get the bulb tester built up and use it every time you test a piece of equipment whether you have built it from scratch or modified it or just carried out what appears to be minor maintenance.
It may save you a potentially Lethal accident.
regards Andrew T.
Sent from my desktop computer using a keyboard
110v or 220v, how can you tell? fjmart134 Tubes / Valves 2 8th June 2009 11:18 PM
VELODYNE 110V to 220V iblieve Power Supplies 1 11th May 2009 08:25 PM
How to rewire Soundcraftsmen Pro Power 4 from 220v to 110V? warrenhud Solid State 1 7th April 2009 07:33 PM
Can you rewire 220V for 120V? Lewis Moon Solid State 6 18th February 2009 02:50 AM
AR XA 220V to 110V dan duette Analogue Source 2 13th February 2009 02:08 PM
Copyright 1999-2017 diyAudio
