#41 |
Rej,
I know the Owner of Stranger "Mr. Tapan" in Kolkata very much and i very well know his calibre, he cannot ever dare to offer smps in his amp, no matter how they are marketed.... If he will offer, then he must be in problem...as you said... Also not even the Ahuja owned Studiomaster offer SMPS in their amps..... Could you post an inside & outside photo of Stranger with SMPS..if it really exist...... K a n w a r |
#42 |
Workhorse,
I think the important issue is not whether Stanger produce smps amp or not. Im not bothered which one make them.. The dealer give us some info regarding smps amplifiers and the problems they are having. He then mentioned the name stranger or so...But all of the commonly used one has the noise problem as already stated. The only key idea is to make a noiseless smps amp. -rejith |
#43 | |
You have given insufficient info...... First of all collect the required info such as Scope Traces of Generator waveforms , Schematics of SMPS which are having problem, then only one could help you out.... You dont have access to Scope and nor you know how to read the facts from Waveform, nor you want to analyse the problem deeply....You specialise in different field that is DSP and not in SMPS.......Then you must Tell us what Sould be done to solve your problem K a n w a r |
| Germanium transistors work fine in output stages ? | aldovan | Solid State | 30 | 5th February 2010 09:18 AM |
| Need clue. R speaker static when low volume, fine loud, headphones fine. . . Help? | danielwritesbac | Solid State | 4 | 30th December 2007 03:29 PM |
| Power horizontal deflection transistors work fine in output stages ? | aldovan | Solid State | 7 | 31st August 2007 01:31 PM |
| head unit problem.No output through interior speakers but rca outs work fine | spooney | Car Audio | 2 | 1st January 2007 11:08 AM |
| No reclocking DAC. Are they fine? | beppe61 | Digital Source | 22 | 15th September 2005 03:14 PM |
| Page generated in 0.09730 seconds (64.62% PHP - 35.38% MySQL) with 11 queries |
