Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd November 2006, 01:27 AM   #1
VEC7OR is offline VEC7OR  Lithuania
VEC7OR's Avatar
Send a message via Skype™ to VEC7OR
Default Offline ~500W SMPS
Hi everyone, I've decided to biuld an offline SMPS.
It will have around ~500-600W of power (in the top range for the half-bridge designs). Any comments on the topology of the circiut ?
I have couple of questions about:
1) current transformer, what magnetic material is better to use for it ?
2) I've read alot of scary stories about flux imbalance/walking during regulation of the PSU, how bad is it with half-bridge design ? I'll have cycle by cycle current limiting implemented, so I think it wont be a problem, if core will go into saturation it should be corrected through current limiter, right ?
3) Do I require any freewheeling diodes for this design (apart those in FETs, but they are slow and stuff)?
FETs most likely will be IRF740 or similar, switching frequency around 75kHz.
Controller and driver are LM5030 and IR2110. I chose those because they are easy and relatively cheap to get plus I think I understand how LM5030 works good enough to try it. (Yeah, I also plan using it for car SMPS, but thats another story)
Profanity took a very interesting form in Russia where there exists a language of sorts, most of its words based on four basic profane roots - nouns p...is, wh.0.e, c..t and verb f..k. It is possible to sensibly communicate using just these four basic roots.
Old 2nd November 2006, 05:44 PM   #2
subwo1 is offline subwo1  United States
subwo1's Avatar
Hi. If you place something like a 1uF film capacitor in series with the transformer primary, that should remove concern about transformer saturation. You could change things a little more, even. Use one bulk filter capacitor. But then use two film capacitors in series across the big electrolytic one. Connect the transformer primary to the midpoint between the film capacitors.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 2nd November 2006, 07:17 PM   #3
N-Channel's Avatar
Send a message via AIM to N-Channel
I would also add a mutually coupled inductor right after the output diode bridge before the filter caps.
Have you considered PFC? Since you're not making this 115-230V switchable, very high voltage (>300V) won't be a concern. This would lower, dramatically, the peak currents that would be going through the input diode bridge.
Othar than that, It looks good. Coilcraft makes some off-the-shelf current sensing transformers that are good for 50-200kHz.
Steve
Old 2nd November 2006, 09:35 PM   #4
VEC7OR's Avatar
I've been thinking about it, but what about staircase saturation ? Another thing that how big those caps would be ? Hm, the frequency is rather high, so something in ~1-2.2uF would do.
Steve
Hm, PFC, yeah, up to a point, but this adds complexity and reduces efficiency a bit, and what PFC method would you recommend ? In that case I would choose boost converter based PFC with continous conduction mode, using IR1150, so far its the best solution I've seen, least component count, easy to implement, very high power possible. Another thing that PFC at 500-600W requires a hefty inductor.
I've also thought about adding a mutually coupled inductor, for that very purpose I have some slotted toroids (Epcos, N27 material), these just dont saturate
Thanks for pointing out on Coilcraft, its a pity no local distributor carries their products, but i think I'll order from them directly.
Old 2nd November 2006, 11:09 PM   #5
subwo1's Avatar
I'd say that to lessen the ability of the transformer to saturate that way or in any other is one advantage of using the coupling capacitor or capacitors. It is even possible to use much smaller of this primary coupling capacitance than normal. Then you would need a couple of high speed diodes to shunt resonance peaks to the power supply rails. You lose a little efficiency, but the primary circuit may gain simplicity and some extra current limiting if you can do away with the current mode control. During overload then, the circuit will move toward switching at zero primary current, depending on the voltage on the secondary side.
USMPS
Old 6th November 2006, 03:01 AM   #6
N-Channel's Avatar
Vec,
For your mutually-coupled Inductor, I would grab the BIG yellow toroid out of an old PC supply, and re-wind it for your application. These NEVER saturate, and they are cheap and readily available, usually for a song.
Yes, I would also stick with continuous-conduction mode boost converter for the PFC, because it is the preferred method for power levels over ~300W.
Unitrode's UC3854 is a good candidate because it operates constant-frequency, and can be synch'ed with the PWM.
Steve
Old 7th November 2006, 07:59 PM   #7
VEC7OR's Avatar
Vec,
Steve
I know that those are good, but I got these toroids from a dude who designs SMPS's for like 30 years, he said that he tried numerous ways to overcome losses and saturation, used many types of materials and says that this is the best he came up with.
I think I'll skip the PFC this time, moreover in my country, we dont pay for reactive power and PFC isn't a requirement, YET.
Here is the second version of the psu, now the trasformer is connected to smaller capacitors and electrolytics are on rails.
I've been thinking about using a toroid for this project, but for offline we need better isolation, so I plan to order some EDT cores from Distrelec, EDT44 - EDT59 range, or should I better stick with toroids ?
P.S. I can attach the bigger schematics if anyone is interested.
Old 7th November 2006, 08:16 PM   #8
subwo1's Avatar
My vote is for the toroids.
USMPS
Old 9th November 2006, 01:46 AM   #9
N-Channel's Avatar
Subwo: I wonder why? I'm suffering from Avatar-envy.
VEC: Just an idea, I would place the first set of 470mF caps on the secondary side AFTER the 20 mH inductors. I looked at the datasheet for the LM5030. Slick little chip.... Since PFC is not in the cards for now, that's fine, but I would rate everything on the primary side for 500V nonetheless, so when (and if) you decide (or have to) PFC the front end, you won't have to change a whole lot, just the primary windings.
Oh, I vote for the Totoids, too.
Old 9th November 2006, 01:34 PM   #10
subwo1's Avatar
N-Channel, we can let the toroids and the e-core androids duke it out. Now I realize what the kids are watching in that television cartoon.
USMPS
500W offline SMPS mag Power Supplies 99 12th June 2009 11:37 PM
13.8V 15A offline SMPS w/ PFC djQUAN Power Supplies 18 31st March 2008 11:43 AM
offline SMPS regulation Pierre Power Supplies 0 12th April 2006 05:25 AM
Copyright ©1999-2013 diyAudio
