LM7812 Test, PSRR 60dB at 100Hz ripple
Old 29th October 2006, 04:38 AM   #1
lineup is offline lineup  Sweden
lineup's Avatar
Smile LM7812 Test, PSRR 60dB at 100Hz ripple
hi
Trying to figure out how to setup
Power Supply Rejection Ratio = PSRR testing
using my Multisim spice simulator.
Have a look at my attached test circuit.
1. I am feeding 100mV ripple 100Hz onto a 12V regulator input.
2. Then I measure the AC voltage at the output.
3. In this setup I use 100mA DC load with a normal electrolytic decoupling capacitor.
Result:
Ripple at input: 100mV
Ripple output: 114uV = 0.114mV
Ratio: 100 / 0.114 = 877
20 x LOG10( 877 ) = 58.8dB
PSRR = 58.8dB at 100Hz ripple ( with ripple level 100mV )
This looks as a value that may be correct and valid.
Questions:
->> Is this a good method of estimate PSRR?
->> What setup do you use?
->> Is there some standard method used for example by Op-Amp manufacturers?
lineup
lineup
Old 29th October 2006, 07:08 PM   #2
lineup's Avatar
Arrow The Best Audio Lab - Lineup
okay
never mind
I understand now:
I am the only one diyaudio amateur constructor
that actually design my amplifier
to have a good PSRR and try to make this sure by
doing some simulations and tests
lineup
The Best Audio Lab
The Most Serious Audio Lab:
Lineup Audio Lab
http://lineup.awardspace.com/
lineup
Old 3rd November 2006, 06:54 AM   #3
mrjam is offline mrjam  Italy
mrjam's Avatar
OK! Never mind!
You understood what??
You're the only one diyaudio amateur constructor that actually design your amplifier using Electronic WorkBench!
Maybe it's the reason why people ignored your "discovery"! Nobody cares about PSRR "measured" with a sim!
You talk about music you can hear and loose time with EWB ....stop sims and connect a "real" function generator and a "real" oscilloscope to your "real" 7812 connected to a "real" circuit! You will discover parasitics, oscillations and other "real" things
Good luck with your beloved simulations!
Old 3rd November 2006, 07:21 AM   #4
edl is offline edl  Hungary
edl's Avatar
Hi HALOJOY,
I visited your webpage, Lineup.
Had a good laugh, thanks!
Mrjam is right, in EWB measuring 7812's PSSR means nothing. Measure it in your Lab. In such a serious laboratory I'm sure you have the needed gears. I'm sure you have a really nice workbench.
"I am the only one diyaudio amateur constructor
doing some simulations and tests"
haha...
http://lineup.awardspace.com/labtour-1.html This is that Audio Lab?!
Old 3rd November 2006, 08:01 PM   #5
powerbecker is offline powerbecker  Germany
Hi lineup,
1->> Is this a good method of estimate PSRR?
2->> What setup do you use?
3->> Is there some standard method used for example by Op-Amp manufacturers?
1- yes!
2- the same, but you can "save" R1.
3- I donīt know but why not,
may be You ask Bob Pease?
Of course not : Itīs always the best to try some simulations
b e f o r e one build and test!
Heinz!
Old 5th November 2006, 12:25 PM   #6
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
You can just capacitively couple your AC signal to the supply voltage as is shown in this diagram: http://i.cmpnet.com/eet/news/03/july/SS1278_ADI.gif
Brian
Old 5th November 2006, 01:53 PM   #7
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
i use simulation only for digital circuits . the the only case it works the same as in reality
if you are not living on the edge you are taking too much space
Old 6th November 2006, 02:12 AM   #8
mitwrong is offline mitwrong  China
mitwrong's Avatar
Send a message via AIM to mitwrong Send a message via MSN to mitwrong Send a message via Yahoo to mitwrong
Default we do what we needed
Hi, Lineup
I have visited Ur web, it's interesting, I want to know what's the purpose of Ur Lab, for business, for fun, or an ad.
anyway, we do what we needed. the way to measure 78XX is not important, the point is we buy a component that can meet our application is enough. Too precise is a waste. We only consider price verse perfomance. any component manufacturer can provide spec. for their products. no necessary to do extra work on testing.
I've been using the 78XX series regulators for decade, and they gave our performance is over their value. to measure their spec. is meanningless.
WE CONSIDER PRICE AND PERFORMANCE
LM7812 Test, PSRR 60dB at 100Hz rippleHide this!Advertise here!
Need -60dB 1kHz sine wave for CD Bernhard Digital Source 30 26th March 2012 11:31 PM
FFT Noise Spectrum of the LM7812 three terminal fixed voltage regulator rjm Power Supplies 7 24th December 2009 03:59 PM
lm7812-22v/2A in? reever Parts 4 21st April 2005 12:20 PM
Lm7812/7912 kinser Chip Amps 9 22nd November 2004 09:55 AM
