Traffo connection QS
Old 20th October 2006, 06:46 PM   #1
Bassivus is offline Bassivus  Serbia
Bassivus's Avatar
Default Traffo connection QS
How is the best to connect the primary when I measure 226V mains?
What is the yellow/green - it says:"blind winding" for?
Old 20th October 2006, 07:32 PM   #2
cerrem is offline cerrem  United States
cerrem's Avatar
First thing first....
Check continuity of ALL wires and put wires into groups have continuity...this way seperating the windings....
Sounds like this wire "may" be a shielding wire with only one end terminated.... You need to see if wire has any continuity to any other group of wires...if not, then it may be a faraday winding for shielding..
Chris
Old 20th October 2006, 08:52 PM   #3
Bassivus's Avatar
Thanks for reply Chris!
I have checked for continuity and y/g wire is separate of all the rest. I guess than it is like you said Faraday winding for shielding. Should I connect it to some ground?
Next I have checked the resistance between white,orange and black. It reads: w/b=29,1R ;w/o=30,7R.
Old 22nd October 2006, 12:33 PM   #4
Bassivus's Avatar
Anybody?
Should I connect the yellow green shelding wire to mains ground or...?
White is marked 0, Black 220, Orange 230. I have checked the resistance between white,orange and black. It reads: w/b=29,1R ;w/o=30,7R.
What is the best to connect the primary when I measure 226V mains?
Traffo connection QSHide this!Advertise here!
Modushop.biz heatsinked enclosure + F5 Amplifier (Nearly Complete) incl traffo rhysh Swap Meet 10 3rd July 2009 10:08 PM
big valve traffo for guitar amp? Craig405 Instruments and Amps 15 9th October 2007 10:53 PM
pot connection rocktboy Chip Amps 2 25th June 2003 09:31 PM
