Voltage Regulation from a battery - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 11th October 2006, 07:48 PM   #1
bigphil is offline bigphil  Canada
Default Voltage Regulation from a battery
Hey guys, I know this isnt audio related but I think that a few of the EEs around could answer my question in 5 seconds.
I'm trying to put together a project for school. I have a 12V (nominal) battery, and need to power 5V motors with the least amount of wasted energy possible (obviously). I know that a 5V regulator can do the job, but I have also learned about step-down dc-dc converters and have found a few chips that would do the job as well. Example: LT1108. DOes anyone know what would be my better option? the regulator would be powering a PWM setup with mosfets. Seems simple enough, but there are phDs written on the topic. Thanks in advance.
Old 11th October 2006, 07:59 PM   #2
If efficiency is your main goal, then DC to DC conversion method will win by quite a margin, esp. when you realise a 12v lead-acid is about 13.8v fully charged. Even a crude switched-mode supply will better 80% efficiency, whereas the linear reg cannot improve upon (5/13.8)*100, or 36%. HTH.
Old 12th October 2006, 04:36 AM   #3
CBS240 is offline CBS240  United States
CBS240's Avatar
Perhaps maybe a step down buck converter might be simpler and acomplish the same goal? How much current is involved here?
All the trouble I've ever been in started out as fun......
Old 12th October 2006, 04:46 AM   #4
johndiy is offline johndiy  Greece
Banned
regulator
Old 12th October 2006, 05:12 AM   #5
around 500mA I think... its for a small rover.
Old 12th October 2006, 05:46 AM   #6
clem_o is offline clem_o  Philippines
Default Re: Voltage Regulation from a battery
If that's the case, don't bother with the regulator. You can always set the PWM to a maximum of 5V/12V = 41.67%.
That will give you maximum efficiency at the same time. Such limiting can be built into the code of the microcontroller (if it's to be servo-controlled by such).
Just make sure that the PWM frequency is fairly high so that the motor inductance naturally smooths out the pwm pulses...
Cheers
Old 12th October 2006, 06:24 AM   #7
Electrons are yellow and more is better!
peranders's Avatar
Why don't you check Simple Switcher from National. You'll need only a few parts.
http://www.national.com/pf/LM/LM2675.html
The efficiency approx. 90%, not extremely high but better than a linear regulator.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 13th October 2006, 05:23 PM   #8
Clem has hit it straight off in post6.
Don't bother with intermediate voltage control.
Let the PIC do the whole job and limit the mark:space as suggested.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 13th October 2006, 11:24 PM   #9
You can even go beyond 46% for short intervals, giving you extra 'grunt' when accelerating/stopping... I can guarantee it works - students in mobile robotics do it regularly.... :-)
Cheers!
Clem
Old 14th October 2006, 03:44 PM   #10
Thanks guys, I will give it a try.
Voltage regulation for TL494? thunderpld Power Supplies 0 14th March 2009 10:28 PM
OD3/OA3 voltage regulation design Carlp Tubes / Valves 1 21st February 2008 05:57 AM
Thyratron voltage regulation rcavictim Tubes / Valves 2 2nd March 2007 09:25 AM
voltage regulation for input buffer in UcD zilog Class D 3 16th October 2006 04:48 PM
Regulation in battery supplies Jarno Solid State 0 19th September 2002 08:20 AM
Copyright ©1999-2017 diyAudio
