need help understanding voltage regulator schematic (using CCS) from Raleigh Audio - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th September 2006, 07:07 AM   #11
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally posted by jarthel
hope this text schematic comes out clearly
230VAC transformer secondary -> tube rectifier -> choke (10H 90ohm) -> 100uF -> CCS circuit (70ma? - not sure yet) (as found in Bas Horneman's website) -> the voltage regulator as found in the raleigh audio website.
using PSUD2, the voltage across the 100uF is 170VDC. I need 150VDC at the output of the raleigh audio circuit.
I'm just confused on how to calculate the R1 and R2 values to get the 2.5V for the TL431 and at the same time, the resistor values will determine the B+
Resistors represent a negative feedback. The IC compares the voltage on input against internal 2.5V it has "in mind", and if the voltage is higher it draws more current that causes the tube to draw more current until the IC sees 2.5V on the input, and vice versa.
You defenitely are asking wrong people why that particular guys put such strange schematics on their website. Ask them.
Old 26th September 2006, 09:17 AM   #12
jarthel is offline jarthel  Australia
this website is called a "discussion forum" for a reason wouldn't you think?
Old 26th September 2006, 02:06 PM   #13
Originally posted by poobah
Jarthel,
What exactly are you trying to regulate? I ask because shunt regs have to be applied rather carefully...
The is a bit abstract but, shunts are to used to regulate a current. That is not to say it is a "current regulator"... it's not. A shunt regulator needs to have a current source for a supply... not a voltage.
Just one resistor solves all this basically...
the examples in onsemi's tl431 datasheet uses Vin so maybe it also uses voltage?
Old 29th September 2006, 01:05 AM   #14
Hi jarthel,
poobah provided a correct formula in post #5 above. So, if you pick R2 to be 24.9K and want your B+ to be 150V,
R1 = (24.9k * (150 - 2.495)) / 2.495 = 1.47M
Now, it turns out that 1.47M is a standard value so you are done.
However, often it doesn't turn out that close and you will have to play around with the values of R1 and R2 to get the value for B+ that you want.
Dave
Old 29th September 2006, 01:12 AM   #15
Originally posted by David Davenport
Hi jarthel,
Dave
some question on the circuit: does the tube protect the tl431 from over-voltage or "over-current" or both?
Old 29th September 2006, 02:08 AM   #16
The tube provides isolation from the high voltage. The tube is in series with the TL431 so the same current goes through both.
The tube should be chosen by its max plate voltage and max plate current plus a bit for good measure. For plate voltage I usually pick the value of the regulated voltage as a limit. So in your case any tube that can have 150V or more on it. You don't need much current, just the expected variation in the load current plus a few, say five, milliampers.
Dave
Old 29th September 2006, 02:15 AM   #17
Dave
thank you for the help
Old 29th September 2006, 02:33 AM   #18
poobah is offline poobah  United States
poobah's Avatar
Jarthel,
What are you going to regulate with this? A voltage source?
Old 29th September 2006, 02:47 AM   #19
Jarthel,
my mistake on that
I didn't realize that on the onsemi datasheet, there is a resistor before R1/R2 (which means it's a current input)
Old 29th September 2006, 03:02 AM   #20
poobah's Avatar
Right... the "new" resistor is what drops the voltage down to your desired regulated voltage.
In order to calculate the 3rd resistor, you need to know your max and min load current... and the raw voltage, and the regulated voltage.
Help with schematic understanding sumo Tubes / Valves 6 2nd May 2009 11:07 PM
Raleigh Audio Preamp - somebody heard ? dejanm Tubes / Valves 4 14th January 2008 01:15 PM
Audio Note M2 regulator schematic drobert Tubes / Valves 1 10th November 2007 03:09 AM
irf610, irf9610 voltage regulator schematic needed for +/-15V sunrise Solid State 4 22nd June 2006 08:57 PM
Help Understanding CD Player Output Voltage, etc. Stew Digital Source 5 26th February 2006 02:39 PM
Copyright 1999-2017 diyAudio
