diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   oops!! (http://www.diyaudio.com/forums/power-supplies/86674-oops.html)
Danko 17th September 2006 04:48 PM
oops!!
I was testing my 50V -> 5-15V synchronous buck regulator, when the 0.01R current sense resistor, series with the 50V DC bus exploded, and the PCB was burning in flames :)
The output current was about 60A. I think the mosfets cross-conducted, and they become a "short-circuit", and the 0.01R burned.
The MOSFETs were FDP3632, paralelled 2 on the upper side, and the lower side.
btw, the 1.5mm^2 wire in a bucket of water was a good dummy load :-)
Here was the resistor....
http://sziget.mine.nu/~danko/aramkor...t/dscn0466.jpg
Wear eye-protecting glasses, when you experiment with high power stuffs!!!!
Your safeti is the most important!
(I was wearing also)
ifrythings 19th September 2006 07:58 AM
Umm... what resistor??? all I see is masive pile of charcole...:D
Tell me about eye protection, had a chunk of mosfet almost hit my eye (about an inch away) now I always wear saftey glasses when first or testing time come :D
Eva 19th September 2006 11:53 AM
I can only see a pile of junk in that picture, how about showing the actual prototype?
poobah 19th September 2006 05:02 PM
You have cross-conduction... or, you ran out of inductor (saturation).
The joys of SMPS desing!
:D
Workhorse 19th September 2006 05:52 PM
:D
Hi poobah,
It seems to me that you dont need to wear glasses to protect your eyes from the small wonders of smps designing!
;) :D ;)
JensRasmussen 19th September 2006 06:04 PM
Re: oops!!
Cool pic :flame:
You might suffer from uneven power loss in the fets as you have two in parallel......
I always use one big fet rather than two..... much better solution IMHO.
\Jens
poobah 19th September 2006 06:41 PM
...ahem... DESIGN...
Nordic 19th September 2006 08:45 PM
Actaly Poobah looked normal until the day wanted to see close-up what made a nest of tantalums smoke....
poobah 19th September 2006 09:22 PM
I have blown up up tantalums... how did you know?
Ever seen a wookiee on fire?
:D
subwo1 20th September 2006 09:45 PM
I found that using only one gate resistor per paralleled MOSFET set ended a problem with them failing.
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
