oops!!
oops!!
Old 11th October 2006, 04:11 PM   #31
luka is offline luka  Slovenia
luka's Avatar
oops!!
How is the project coming along?
Old 13th October 2006, 05:53 PM   #32
Danko is offline Danko  Hungary
I have /now/ a few experiences. The efficiency is very low (about 70%) at 20A output current, becouse the U_in is far more higher than U_out, and /becouse of this/ the switching losses are dominating, not the ohmic (RDS_on) losses.
I couldn't decrease the switching frequency, becouse then I would need a huuuuge output inductor. The core is quite big, about 4cm outer diameter, and 2cm inner diameter. Only 4 turns are on the inductor, and I think it still saturates, when I go over 20A. I can't decrease the turns on the inductor, becouse then the dI would be too high. Now (with 4 turns) the core is very hot even if I use active cooling, with a small 486 CPU fan.
I will try to get/make an inductor core, wich can "hold" more energy.
Best regards, Danko
Old 13th November 2006, 11:35 AM   #33
luka's Avatar
oops!!
Did you make an inductor core, wich can "hold" more energy yet?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 21st January 2007, 10:07 AM   #34
luka's Avatar
oops!!
Hi danko
How is the project coming along. If not to good there is a thing you can do/think about it.You and I try to drive N-channel mosfet with IRxxxx, trying to drive its gate over the input(max circuit voltage). But there is much simpler way. Use P-channel mosfet and you dont even need IR, the PWM chip can drive it directly.
What do you think?
I FEEL SLOVENIA
oops!!Hide this!Advertise here!
Oops..i removed leds from amp circuit board cliffy Parts 5 5th January 2008 03:52 PM
Oops! Now what? cytokine Subwoofers 17 31st August 2005 12:33 PM
Oops.. May have fried my M-audio SuperDAC 2496 motherone Digital Source 3 11th March 2005 09:09 PM
Blew my first Chip ..Oops Help not doing it again? Adam M. Chip Amps 13 6th September 2004 03:08 PM
Oops squashed my smoothing caps!! Beggar Parts 1 6th September 2003 09:43 AM
