oops!! - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 21st September 2006, 06:28 PM   #21
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
oo and how do you charge cap, that is in high side of IR?
With costant voltage and his reference connected to drain of mosfets?
Old 21st September 2006, 06:32 PM   #22
luka's Avatar
You should make dead time with tl494 not some where in the circuit with R-C
Old 21st September 2006, 06:33 PM   #23
Danko is offline Danko  Hungary
That capacitor charges through D1 and /inrush current limiting/ R28.
The cap is connected to the source of the high-side mosfets.
Best regards, Danko
Old 21st September 2006, 06:40 PM   #24
luka's Avatar
oops my mistake, I ment source.
Ok I see how you got it.
I will have to check at home how I have done this.
While I think now I think I have made it too complicadet
Old 21st September 2006, 06:41 PM   #25
I need the PWM signal, coming from the TL494, and the inverse of the signal. TL494 cannot make the inverse of the signal, that I need.
I can invert the PWM with a single transistor, like a BCxxx, or with a TTL/CMOS inverter, or I can connect the TL494's transistor's in the way, you can see on the schematic.
When I use TL494 in push-pull mode ( OUTC tied to VREF ) then both the outputs will have the same duty cycle. For example 30% 30%, but I need to drive the high-side MOSFET with 30% Duty-cycle, and 70% duty-cycle, the lower MOSFET.
Best regards, Danko
Old 21st September 2006, 06:46 PM   #26
luka's Avatar
aha that's whay I use only Hi mosfet
Old 21st September 2006, 06:47 PM   #27
Yes, that's simpler. That is lower efficiency, less complication, less fun :-)
Best regards, Danko
Old 21st September 2006, 06:50 PM   #28
luka's Avatar
That is lower efficiency, less complication, less fun, but since this is not for me and I don't have 5 years to make it, it will have to do
Old 22nd September 2006, 06:56 PM   #29
I was experimenting a little bit in my simulator.
I created a schematic, wich makes about 750nanosec dead-time.
Is that too much? Or too short?
T1 transistor is the TL494's output transistor. I applied 50% duty-cycle square-wave to the transistor.
On the schematic there is CD4069, becouse the simulator haven't got CD4049 in it's library. I'm going to use CD4049.
What do you think of this? Will it work in the real world? :-)
Best regards, Danko
Old 23rd September 2006, 04:58 PM   #30
luka's Avatar
I think that time is quite good, maybe make it variable.
Oops..i removed leds from amp circuit board cliffy Parts 5 5th January 2008 03:52 PM
Oops! Now what? cytokine Subwoofers 17 31st August 2005 12:33 PM
Oops.. May have fried my M-audio SuperDAC 2496 motherone Digital Source 3 11th March 2005 09:09 PM
Blew my first Chip ..Oops Help not doing it again? Adam M. Chip Amps 13 6th September 2004 03:08 PM
Oops squashed my smoothing caps!! Beggar Parts 1 6th September 2003 09:43 AM
Copyright 1999-2017 diyAudio
