oops!!
oops!!
Old 21st September 2006, 02:00 AM   #11
ifrythings is offline ifrythings  Canada
ifrythings's Avatar
Originally posted by poobah
Ever seen a wookiee on fire?
Got pictures or a movie
Old 21st September 2006, 05:03 PM   #12
Danko is offline Danko  Hungary
Hi!
Finally, back from school....
Here are 2 pictures from the prototype, as Eva asked :-)
http://sziget.mine.nu/~danko/aramkor...t/dscn0465.jpg
http://sziget.mine.nu/~danko/aramkor...t/dscn0453.jpg
The actual state is not exactly that, on the picture. I removed the 0.01 Ohm SMD resistors from the PCB, and moved to a separate small PCB. (not that, wich exploded)
This is on picture 0465. There is some calculation, on the desk
poobah! I gonna lower the inductor value. I haven't thought the inductor....
I have a small problem with dead time. If there is no dead time, that is a problem. Cross conduction, and smoke, and other bad things happen... If there IS dead time, then there is a short time, where none of the MOSFETs are conducting, so the inductor's stored energy can cause a voltage spike on the MOSFETs. The inductor is about 9-10nH. Can this inductor cause such high voltage spike, that can kill a 100V MOSFET? How can I avoid this spike?
JensRasmussen!
I had to use 2 paralelled MOSFETs, becouse I only had "just" 80A types.
Best regards, Danko
Old 21st September 2006, 05:10 PM   #13
poobah is offline poobah  United States
poobah's Avatar
Danko,
If you are sure you have no deadtime, that is the first place to work...
During your dead time, the inductor will draw its current from the body diode in the lower FET, this should not cause a large spike. But, the body diode of a Low-voltage FET is not the best thing either.
Check your calculations for peak inductor current. If your inductor saturates; it becomes a short circuit.
P.S. 9nH does not sound right. What is your Fs, Vi, Vo, and Po?
Old 21st September 2006, 05:16 PM   #14
ifrythings's Avatar
I believe a snubber across the mosfets will suppress any large voltage spikes that the deadtime will cause.
Old 21st September 2006, 05:21 PM   #15
luka is offline luka  Slovenia
luka's Avatar
oops!!
Can I see your schema, please?
Would it be OK if I would use ONLY uperside mosfet and diode?
Old 21st September 2006, 05:24 PM   #16
poobah's Avatar
Yes... but you must replace the lower Fet with a good switching diode.
Old 21st September 2006, 05:56 PM   #17
Yes, schematic is coming soon. I just have to make it "human readable" format. It's quite messy....
poobah:
Fs=222kHz
Vi= 50V DC , from a 1.5kVA toroid
Vo=2.5V-15V
Io= /max/ 70A
7 turns on the inductor, and 70A /neglecting the dI/ through the inductor is 490 Amper*turns. The core, I'm using, the max. Amp*turns is about 7-800.
It should not saturate....
About dead-time.... I placed on the PCB R-C 's, but I think they caused too small dead-time.
luka: I have only ~20A diodes, and I had to paralelled many of them, to achieve safe operation. Oh, and the power loss would be almost double.
Best regards, Danko
Old 21st September 2006, 06:23 PM   #18
luka's Avatar
oops!!
I will use diode RURG8060 and my freq. is 50kHz, input voltage is 45DCv from 2kw trafo, I aim at 13.8v at 70A to charge several car baterys.
Old 21st September 2006, 06:25 PM   #19
luka's Avatar
oops!!
How big are those spikes? I intende to use 100v mofets to.
Old 21st September 2006, 06:26 PM   #20
The schematic:
http://sziget.mine.nu/~danko/aramkor...-06_201024.png
some notes:
The "voltage" line somes from the output. On the output there's a pot.meter, the "voltage" line is connected to it's wiper.
The "current" comes from a rail-to-rail ( Texas TLC2272 ) op.amp. The current shunt's voltage is amplied by the op.amp.
the circled R-C parts are makeing the dead-time. But... There's is a mistake, I think. One R-C slows down the turn-ON, the other slows down the turn-OFF.
The feedback around the TL494 isn't final.
Best regards, Danko
oops!!Hide this!Advertise here!
Oops..i removed leds from amp circuit board cliffy Parts 5 5th January 2008 03:52 PM
Oops! Now what? cytokine Subwoofers 17 31st August 2005 12:33 PM
Oops.. May have fried my M-audio SuperDAC 2496 motherone Digital Source 3 11th March 2005 09:09 PM
Blew my first Chip ..Oops Help not doing it again? Adam M. Chip Amps 13 6th September 2004 03:08 PM
Oops squashed my smoothing caps!! Beggar Parts 1 6th September 2003 09:43 AM
