seperate power supply? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th September 2006, 04:06 PM   #1
Default seperate power supply?
Is it ok to have the power supply in a seperate enclosure to the main power amp?
If so can anybody answer the following please
1. What do you do about grounding? seperate single point chassis ground in each connected together?
2. What connectors work well for both the B+ and heater supplies?
Old 12th September 2006, 04:14 PM   #2
FastEddy's Avatar
Default no problem-o
... yes, power supplies in seperate enclosures is possible, but not necessarily easy.
Advantages: with seperate enclosures the supply is "isolated" from the main circuit(s) and the cases can serve to seperate the noisey supply from the action in the main case = better filtering is possible.
Disadvantages: obviously there is a much higher parts count = two cases instead on one plus the interconnection hardware.
1) A single ground connect at the output of the external supply ... a star ground network from that point = a good "loop free" design.
2) Connectors? I prefer Molex type plugs and sockets, but others here will probably suggest alternates ... truth is one, paths are many ...
(There is a lot to be said for using a sperate supply for the pre-amp and associated interfaces ... and having a seperate, external 12 VDC supply (or +/- 12 VDC) with associated battery (as "filter" & storage) can be very useful & very successful at powering several "low level" devices and DACs.)
Old 12th September 2006, 06:14 PM   #3
Sherman is offline Sherman  United States
I've used Molex connectors successfully but I think the connectors from Neutrik (sp?) are excellent. They have a 'twist-lok' connection that makes positive contact and won't fall out. They also make it virtually impossible to touch the contacts, important with HT.
--Sherman
Old 12th September 2006, 09:47 PM   #4
Alain Dupont's Avatar
matthew2456,
Take a look at my site under SE 6C33C-B
The PS's for each channel are on a separate chassis...
Work pending!
Using Amphenol connectors military serie... PT 06 Serie: MIL-C-26482
14/12 for 12 contacts 8 #20 and 4 #16 {Digikey}
1000 Volts AC
Each supply has 2 cables and the connections are made only on the amplifier...
Ground is on the Amp chassis only, the PS chassis are grounded to earth.
12.6VDC 3.3A for 6C33C-b
270 VDC B+
420 DC Volts driver
200V DC Preamp
12.6V DC Heaters 6SN7's in serie
5V DC LCD
That's 12 wires serie 300 or 600Volts
Alain.
Seperate/Dedicate 12V Power Supply for TT's Motor mike_junior Power Supplies 0 26th January 2009 02:31 PM
Seperate power supply for pre-amp section in integrated amp? KevinLee Solid State 8 2nd February 2008 10:20 PM
seperate power supply reddish75 Solid State 2 22nd November 2007 10:08 AM
seperate chassis for power supply happyben3 Solid State 16 5th August 2002 06:20 PM
Copyright 1999-2017 diyAudio
