Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th September 2006, 09:34 PM   #1
Default Variacs
I'm troubleshooting a new tube pre-amp that I just finished and am finding voltage after the diode bridge a bit high. It looks like my PS transformers are 115v input and my line voltage is 124v. Thinking about a Variac. I can get a 3-amp Staco from Mouser for $86 or a 5-amp Payne Engineering from Newark for $90. The Staco appears to be a traditional variable transformer, but the Payne calls itself a solid-state variable voltage control with a remote potentiometer that "replaces variable transformers." I'm looking at the 18TBP-1-5 product described somewhat at http://www.payneng.com/ptbp.htm . It has a curious note 4 which says "These controls are not recommended for use on inductive loads." Newark does some explanation of the device at http://www.newark.com/NewarkWebComme...D121/5773.html
Any idea just what this thing is and whether it would accomplish my goal?
John
Old 5th September 2006, 11:38 PM   #2
lndm is offline lndm  Australia
Could it be a glorified light dimmer? Hopefully it's not as noisy as one
Fortunately, there are other options for lowering your B+
Old 6th September 2006, 12:31 AM   #3
tool49 is offline tool49  Canada
tool49's Avatar
I have no clue about the solid state one, but the following one might be worth a look
http://www.mpja.com/directview.asp?product=15162+TR
It's good for almost 5A and is only 49.95USD
The next one up is good for almost 20A and is 104.95USD
http://www.mpja.com/directview.asp?product=15163+TR
Hope this helps!
*By the way I'm not affiliated with MPJA*
Sébastien
Old 6th September 2006, 01:54 AM   #4
poobah is offline poobah  United States
poobah's Avatar
Probably should avoid that solid state gizmo... Your power supply already has a narrow conduction angle. Your PSU voltage may go from 50% to 100% just by turning the control from 4.5 to 5 (just as an example).
Is your overvoltage causing problems? Are there some resistors or perhaps inductors you could change to burn some voltage?
Old 6th September 2006, 02:00 AM   #5
mrshow4u's Avatar
I'd go Iron based. Smoov, simple, delicious
".........These go to eleven"
Old 6th September 2006, 10:27 PM   #6
After a little more reading, it appears that the electronic gizmo is comprised of something called a triac. I think that is somewhat akin to an overgrown dimmer, so is probably too noisy. Thanks for the tip Indm.
Poobah, I'm not sure if the overvoltage is causing me a problem. I'm using tube regulation for the B+ and the regulator is correcting the overvoltage to the desired amount, but I'm also starting my initial troubleshooting effort to find the source of an unacceptable distortion. I don't know if overworking the regulator is a source for the problem. A schematic for the PS is at http://www.diyaudio.com/forums/attac...amp=1051169517
If I tried to burn off some of the voltage, would it be best to do that before the diode bridge or after? Is it better to add resistance to AC or DC? Right now I'm reading about 405v at the 350V measurement point upstream from the 6CW5 tube. Recommendations appreciated. Now I'm leaning towards other than a variac, maybe an RC or LC insertion?
Old 6th September 2006, 10:35 PM   #7
poobah's Avatar
yeah... 405 instead of 350 seems a little hot. I'll look at your power supply...
Have you posted your amp schem as well? The best way to burn some voltage should probably consider how your amp "uses" current... SE PP etc...
Old 6th September 2006, 10:47 PM   #8
poobah's Avatar
You know, as long as you not over loading the EL86, or the cap immediately after the bridge you should be alright.
I am not an expert wth this type of regulator. It could be the extra Va-k affects the regulation... I doubt that is your distortion source though.
Are you getting the 305 (+/- 20V) VDC from circuit? If so, it is stable and quiet under load (music)?
Old 6th September 2006, 11:07 PM   #9
I did get the 305VDC, but I wasn't measuring it under load.
Old 6th September 2006, 11:11 PM   #10
poobah's Avatar
I would guess then that your distortion problem is coming from somewhere else. Do you have a scope?
BTW, the voltage issue may warrant digging into further. As long as the plate of the '86 is not glowing; you're OK for the now. Do you know your amps total current draw from the PSU?
SE or PP?
Variacs, high power electrical. Tweeker Swap Meet 0 14th November 2005 01:13 PM
Variacs for sale JohnG Swap Meet 1 2nd February 2005 02:44 AM
DC variacs? jlg4104 Tubes / Valves 19 29th January 2003 03:39 AM
source for cheap (e.g. surplus) variacs? dorkus Parts 2 6th September 2001 02:47 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
