toroids for mains transformer - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th September 2006, 06:42 AM   #1
groov is offline groov  United States
Default toroids for mains transformer
Could any one please give me a hint of what kind of toroid core (material, size OD, ID) is required to build a mains transformer with .5 to 1KVA spec?
I have research it on the web and found some info from several sources however none of it tells me which type of toroidal core should I use for this type of application.
Thanks in advance
Old 5th September 2006, 10:42 AM   #2
are you planning to buy in the strip metal to wind your own core?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 5th September 2006, 03:17 PM   #3
Please enlighten me, what do you mean by strip metal?
I was planning to use regular insulated copper (magnet) wire probably awg 14 size.
Old 5th September 2006, 03:21 PM   #4
Did it Himself
richie00boy's Avatar
He thinks you intend to make you own core.
Why do you want to wind a toroidal transformer? You can probably find one surplus or even retail that is close enough to your needs. They difficult to wind and you need a special bobbin at least.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 5th September 2006, 04:13 PM   #5
Yes, that is the plan to wind my own coils. Because I can adjust the secondary for the required VA and secondly I would like to build several power amps and the mains transformers are quite expensive.
About 35 years ago I use to wind toroids for a living while attending EE school but at the time it was only a job to put me through school not paying much attention to the details specs for these monsters. So winding a toroid I do not see it as a hugh task what I would like to know is if anybody has an insight on which kind of toroids (material, size, permeability, etc) are used for these monsters.
Old 6th September 2006, 07:04 AM   #6
i'll pay a 1.2KVA 50+50Vac toroidal transformer about 140€, it's competitive to build it yourself? i think no...
Old 6th September 2006, 11:30 AM   #7
buy a secondhand 1.2kVA 45Vac +45Vac for 60euros and add some windings to convert it to 50+50. That's cheaper.
Then add a 10V winding for relay supply then add 8v +8V for the regulated front end supply then .....
Try to buy that new for 140euros.
regards Andrew T.
Old 6th September 2006, 12:19 PM   #8
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
www.toroidy.pl
500VA for $40 / 30 Euro + shipping
1500VA for $110 / 85 Euro + shipping.
see Peter Daniel's post on the ZV9 thread
Old 6th September 2006, 12:22 PM   #9
that is PRICING on the basis of cost input and not on what the market will bear.
More to his business.
regards Andrew T.
Using mains transformer as output transformer Elias Tubes / Valves 176 11th March 2013 09:35 PM
Mains toroids appear to be great for audio bigwill Tubes / Valves 30 9th June 2007 10:37 AM
No mains transformer B+ ? Salas Tubes / Valves 9 14th March 2007 11:04 AM
Reversing mains toroids for HT andyjevans Tubes / Valves 7 9th December 2005 02:03 PM
Mains Transformer Question MlinarS Tubes / Valves 10 25th November 2005 02:56 PM
Copyright ©1999-2017 diyAudio
