Squeezebox power supply - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th September 2006, 07:08 PM   #31
That snubbing cap ... at C4 is a great idea = stabilizes the voltage reference.
Yes, but actually , it's a bit more interesting than that. To be pernickety, it [i]doesn't[/] stabilise the voltage reference but plays impedance tricks that the internal error amp likes.
The reference voltage is based on holding an accurate 1.25v across the upper resistor. This is multiplied by (R2/R1) to get an output voltage of 1.25*(1+(R2/R1)). What C4 does is reduce 'noise gain': to AC signals the voltage gain tends towards (0/R1) - since the cap looks like a very low impedance at HF. This is where the much better ripple rejection shown in the 317/338 datasheets comes from. So, big hint: make Z of C4 much smaller than R2 at twice your AC Mains frequency; 100uF can be better than 10uF.
Better yet, if you can replace R2 with somethig like a zener diode*, you'll get lower noise all the way down to DC - because the dynamic impedance of the zener will much lower than the required value of R2 (just 1-5ohms insteead of 1-2Kohms, say). So it mimics the action of a truly enormous cap at C4 without the potential for damage, or cost. Use a zener in series with a normal diode (anode to 0v), and you get nearly-perfect temperature compensation for free, too
*Output voltage will of course be (Vz+1.25)v
Old 14th September 2006, 08:29 PM   #32
FastEddy's Avatar
Default great report ...
" ... Better yet, if you can replace R2 with somethig like a zener diode ... Use a zener in series with a normal diode (anode to 0v), and you get nearly-perfect temperature compensation for free, too ..."
This is also a neat trick to get closer to a particular desired Zener diode voltage ... each series "regular" silicon diode adds 0.6 Volts to a Zener's value ... so a 3.8 Volt Zener in series with two silicon diodes = 5.0 Volts with (as you say) thermal stabization ! ... and a well regulated 5.0 it will be.
(a trick on cheap solar cell power supplies to fix regulated output at 10.2 V. for a nine volt metal halyde battery. ... 9.0 volt Zener plus two diodes = no overcharging. On 12 volt lead acid batteries = 12 v. Zener + two diodes = 13.2 = no boiling of the battery.)
Old 6th January 2015, 10:39 AM   #33
Sorry, just to make sure. Is it like this ?
Old 8th January 2015, 01:51 PM   #34
Eldam is offline Eldam  France
A question please :
Can the Nazar PS design near this one above could be good enough ? (IIRC it is near the same but BC transistor as currrent follower after the LM regulator !)
Need also a 9 V for my SB Duet as well !
PS : are red led not better than zener here for those few voltages (question of course not statment) ?
Old 8th January 2015, 08:48 PM   #35
had to read all the postings as I'm also interested in a psu for a squeezebox too, I came across this one a while back, still trying to find the time to make it:
http://home.comcast.net/~johnswenson1/stereo/SB_5V.GIF
Wtb: Squeezebox 2 rhysh Swap Meet 5 19th February 2009 02:29 PM
Cyrus II or PSX supply for the Squeezebox? torfi Solid State 0 29th August 2008 11:07 PM
WTB: Original Squeezebox Power Supply dsavitsk Swap Meet 0 8th July 2008 03:58 AM
Squeezebox 3 UK (EU?) jimbo1968 Group Buys 4 4th November 2006 10:05 AM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Copyright 1999-2017 diyAudio
