Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th September 2006, 06:22 PM   #21
pinkmouse's Avatar
The LM338 looks like the best bet then. Get one in the TO3 can and put it on a decent heatsink, as the most likely easily available trannie for that current will be 9V.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 13th September 2006, 06:58 PM   #22
FastEddy's Avatar
Default seconded ...
gsuser: " ... I want to build a new linear one. ..."
pinkmouse: " ... [and get an LM338 in a] TO3 can and put it on a decent heatsink ..."
Seconded, passed by the quarum and put in the out box ... now get to work ...
Old 13th September 2006, 08:14 PM   #23
gsuser is offline gsuser  France
Any advice for the other components values in this shematic ?
Old 13th September 2006, 08:34 PM   #24
You would only need the top half, the part with the LM317. You can also use the LM338, but i don't think you need the headroom.
I have a Roku soundbridge with a Meanwell smps with some filter caps. A slight improvement, more discernable with headphones. Probably going linear would have more positive results. All the best.
Chuck.
Old 13th September 2006, 08:36 PM   #25
oh i forgot!
http://www.muzique.com/schem/lm317.htm
Old 13th September 2006, 09:23 PM   #26
pinkmouse's Avatar
Here's one I made earlier. Set R1 and R2 as per angchuck's link.
Al
Old 13th September 2006, 09:45 PM   #27
FastEddy's Avatar
Default That snubbing cap ...
... at C4 is a great idea = stabilizes the voltage reference.
Old 14th September 2006, 07:16 AM   #28
OK, thanks, it's more precise for me now.
It will be Pinkmouse's shematic, with his recommandation of the LM338 in a TO3 can. Angchuck'link gives me 220 Ohms for R1, and 660 Ohms for R2 withe the LM317. Will it be the same for the LM338 ?
Can you help me with the choice of the transformer ? toroïdal or other ? 9V 25VA ?
Old 14th September 2006, 03:04 PM   #29
FastEddy's Avatar
Default close to prefect ...
... I would be quite satisfied with one of these myself.
" ... It will be Pinkmouse's shematic, with his recommandation of the LM338 in a TO3 can. Angchuck'link gives me 220 Ohms for R1, and 660 Ohms for R2 withe the LM317. Will it be the same for the LM338 ? ..." Yes, similar circuits / chips that use the same basic resistor ratios.
" ... Can you help me with the choice of the transformer ? toroïdal or other ? 9V 25VA ? ..."
Preference would be the torridal type, but there is a plathora of "standard" transformers to chose from. Your target voltage should closely match the specifications for best results from the LM338 = 9 to 15 VDC from the diode bridge (Vin for the LM338) ... so a 9 Volts AC secondary times 1.414 ~= 12.xx volts (the peak voltage from the diode bridge = input AC volts times square root of 2 ~= 1.414 [... which would make this an almost ideal 12 Volt battery charges as well]).
As for the transformer power rating, I like a two to one safety ratio (others may have other preferences) ... so, output power = volts DC times current = 5 VDC times 2.x Amps ~=12 to 14 Watts ... times two for safety and lower heat ~= 25 Watts = 25 VA.
Old 14th September 2006, 03:49 PM   #30
Thanks for these precisions, FastEddy, I can now begin. I'll post a picture when done
Wtb: Squeezebox 2 rhysh Swap Meet 5 19th February 2009 02:29 PM
Cyrus II or PSX supply for the Squeezebox? torfi Solid State 0 29th August 2008 11:07 PM
WTB: Original Squeezebox Power Supply dsavitsk Swap Meet 0 8th July 2008 03:58 AM
Squeezebox 3 UK (EU?) jimbo1968 Group Buys 4 4th November 2006 10:05 AM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
Page generated in 0.13787 seconds (68.07% PHP - 31.93% MySQL) with 11 queries
