diode tandem for gainclone PS - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th August 2006, 03:55 PM   #1
Default diode tandem for gainclone PS
sorry for the noobie question, here I go
Using MUR860 for the minimalist gainclone PS seems to be the ultimate choice here. As far as I can recall the reason is because it is ultra fast. Can it be any faster? Is there any reason for not using eg. STTH806TTI? It is a cheaper tandem and a bit faster than the Onsemis suggested by Peter Daniel. The datasheet is here .
Old 29th August 2006, 04:35 PM   #2
Tweeker is offline Tweeker  United States
Its not so much the fastness (except insofar as it effects softness) as the softness that matters here. MUR860s are already plenty fast. IIRC Peter Daniel tested quite a few FREDs and preffer the MURs, but /shrug.
These diodes are faster still, but watch IFSM.
Be sure your foil hat has a good low impedance ground.
Old 30th August 2006, 09:55 AM   #3
If it's not the fastness, but softness, why not use MSR860 ? Is it too slow (120ns)?
What are the important parameters to watch? Or is it just trial and error?
Do we really need 600V and 8A?
SE Diode kenpeter Tubes / Valves 9 26th May 2008 07:43 PM
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
Battery and a Power Supply working in tandem? Thunau Car Audio 1 23rd March 2006 08:59 PM
Tandem? bellx Class D 2 3rd December 2004 03:56 AM
Copyright 1999-2017 diyAudio
