I copied this schematic off of an ATX power supply, it's the stand-by circuit.
The transformer is a 1 primary, 1 feedback on the same side and one center tapped secondary.(I didn't have the right symbol in my program so I stuck two together)
Only other thing I notice was on the board they had a spot of a resistor going for the emitter of 2SC3150 to base of 2SC945. Any ideas what that mite of been for?
it is used to limit the base drive to the chopper trannie, you shouild use that.
