Cree diodes
Cree diodes
Old 29th August 2006, 02:59 PM   #11
5u4 is offline 5u4  United States
5u4's Avatar
My custom made power transformer came back with no 5V winding, so I decided to just go with it.
If I had to do over, I would have used a type 83. A little finicky to deal with (needs to warm up before hitting it with HV, etc.) , but a fine sounding rectifier IMO.
Old 2nd September 2006, 08:00 PM   #12
TugaTweaker is offline TugaTweaker  Portugal
Default Cree Diodes
I like them . Even against GZ37 Mullard . I dont know about FREDs . I m sure they dont sound harsh in my TT22 SE , Black Gat(ed ), Auricap(ed) , tantalum resistor(ed) , silver wired etc. amp . To me harsh cames mainly from bad components ,or bad audio sources . I put them in a Sonic Frontiers D1 DAC , an AudioNote PS2 AMP and the sound quality from them is superior , certified from different ears of many individuals .
Old 4th September 2006, 01:37 AM   #13
5u4's Avatar
TugaTweaker:
I took your advise that something else besides the Cree's may be causing a very slight harshness in the highs. I've tweeked everything I could inside the amp, all voltages are right on, so what could be going on? I noticed it seemed to be mainly in the right channel.
Then it dawned on me, the schematic calls for 50VDC to be taken from the right channel 2A3 cathode resistor string to place bias on the 6SL7 SRPP driver AC filament. Maybe this is somehow mucking up the sound? I removed it & the harshness is gone! Problem solved, Thanks.
Now there's more hum & buzz as the driver stage filament is floating AC...... now I'm looking at DC filament for the driver stage.
Old 4th September 2006, 05:38 AM   #14
altor is offline altor  Israel
Instead of using DC filament - try to bias AC filament to cathode potential+20-30V.
To do this - make the resistor divider from the plate power supply, to obtain the voltage 20-30V higher then cahode voltage.
Put electrolitic capacitor in parallel with the bottom resistor, and connect this divider o the filament - one side or central point with 2 resistors.
Regards, Alex
www.altor.co
Old 5th September 2006, 10:10 PM   #15
Tweeker is offline Tweeker  United States
Way late reply. Seems you found the issue. PIV for 350-0-350 fullwave is about 1,000V.
Cree 5A 1200V SiC Schottky diode.
Reverse current peaks at ~6uA here.
Be sure your foil hat has a good low impedance ground.
Old 6th September 2006, 02:24 AM   #16
5u4's Avatar
The Cree's are rated at 1200V, as well are the Fred's. After finding the major source of the harshness (DC bias for 6.3V filament taken from 2A3 cathode resistor string) I still prefer the sound of the Fred's over the Cree's.
Got rid of the hum issue with the 6.3V filament supply, by biasing it with what I had on hand, a 9V battery. Totally kills the hum.
On another note: I notice Transcendar has a new line of OPT's on e-bay.
Cree diodesHide this!Advertise here!
Cheapest Cree Diodes? jkeny Parts 0 29th May 2008 12:51 AM
Old Diodes betweenpie Tubes / Valves 2 3rd June 2007 04:06 PM
CREE 1200V 5A SiC diodes 5u4 Swap Meet 5 6th January 2007 08:13 PM
source for Cree Schottky diodes pburke Parts 5 8th August 2004 10:12 PM
