Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th August 2006, 02:54 PM   #1
jarthel is offline jarthel  Australia
Default help customize "slow turn-on" duration in this circuit (link to schematics inside)
http://img112.imageshack.us/my.php?i...titled3bf7.gif
that circuit was found in the datasheet of National's LM150. it doesn't say anything about customizing the duration of the slow turn-on.
also can I also place a 10uF (after the 2nd 1N4002) from Vout to ground?
thanks for the help.
ps. I have just read a similar thread and there were a lot of off-topic replies. please do it somewhere else.
Old 15th August 2006, 03:28 PM   #2
Changing C1 or R3 would change the turn on time.
You could probably put a 10 uF at the output.
Old 15th August 2006, 04:12 PM   #3
pinkmouse's Avatar
Yup, C1 and R3 look like the time delay to me as well. What will you be using this for?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 15th August 2006, 10:36 PM   #4
it's for tube heaters.
2 questions:
1. increasing r3 also increases the delay?
2. how about c1?
thank you for the help
Old 16th August 2006, 12:08 AM   #5
infinia is offline infinia  United States
infinia's Avatar
Hi
R3 and C1 is tau or the time constant. The pnp is clamped on at turn-on so Vout is initially equal to Vref. The output slowly rises to the set output voltage after 3-4 time constants.
50K*100u= 5sec
so output goes from Vref to Vout in about 15-20sec
<edit>
This circuit is a good idea for heater warm up time and to prevent the Vreg from current limiting on start up.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 16th August 2006, 12:11 AM   #6
pinkmouse's Avatar
I'd breadboard this up, and have a play with different values for R3 and C1. The maths is good to know, as Infinia points out, but the hands on approach is more fun, (for me, anyway).
Al
Old 16th August 2006, 12:26 AM   #7
infinia's Avatar
changed c1 to 10uF
Old 16th August 2006, 12:47 AM   #8
can I use this: http://www.ortodoxism.ro/datasheets/toshiba/905.pdf
as the transistor in the circuit? just asking cause I already have it.
ps. to infinia: just sent you an email in regards to spice simulations. thanks again
Old 16th August 2006, 02:47 AM   #9
how about this one? http://www.jaycar.com.au/products_uploaded/PN200.pdf
Thank you for the help
Old 16th August 2006, 03:45 AM   #10
infinia's Avatar
Either or will do, not critical only as a switch during turn on/off.
OLC "Slow Century" Anyone build? screamersusa Instruments and Amps 0 3rd June 2009 05:03 PM
How to get rid of "CKK" Sound on "turn off" riotubes Parts 0 25th November 2006 03:50 PM
Turn on/off thump with "others" D amps...how it is managed? pat allen Class D 11 16th March 2005 07:58 AM
An idea for suppressing the turn-on "bump" Bricolo Pass Labs 11 4th May 2003 06:21 PM
Éxtremly slow diod to "muffle" toroid hifi Solid State 1 31st January 2002 07:44 AM
Page generated in 0.13813 seconds (73.93% PHP - 26.07% MySQL) with 11 queries
