Bridge rectifier - confusion - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th August 2006, 05:33 PM   #1
ash_dac is offline ash_dac  United Kingdom
Default Bridge rectifier - confusion
I am drawing up a parts list for a gainclone, and will probably go for a bridge rectifier configuration.
The bridge rectifier has two ac inputs, and a negative / positive output.
Do I need dual secondaries and two rectifiers for +- supply ?
Also does the negative need to be grounded to centre tap ?
Old 4th August 2006, 05:44 PM   #2
poobah is offline poobah  United States
poobah's Avatar
You need dual secondaries, OR, 1 center-tapped secondary. You do not need 2 bridge assemblies. In the case of dual secondaries, you will need to carefully observe the "phasing" when creating your center tap. The "dotted" end of one secondary must connect to the UNdotted end of the other.
Draw 2 cap in series where you presently show one. Connect the center tap to the node (junction) between the two caps.
Old 4th August 2006, 05:50 PM   #3
poobah's Avatar
Like so...
Old 4th August 2006, 05:57 PM   #4
Like so...
Thanks.
Should that node between the two caps become the star earth ?
Old 4th August 2006, 06:02 PM   #5
poobah's Avatar
Actually, that precise point will have large currrents flowing through it. Some short piece of wire should go from that point to the "star"
Old 4th August 2006, 06:08 PM   #6
FastEddy's Avatar
Default this would work
Old 4th August 2006, 06:10 PM   #7
FastEddy's Avatar
Default followed by this
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
4 rfb-02 rectifier bridge pcb's BeerCan Swap Meet 1 23rd July 2008 07:07 PM
Mass Confusion Over LM3886 Bridge/Parallel Modes and National's Specs.? Travis Clarke Chip Amps 9 1st November 2006 04:13 PM
output diode bridge confusion Danko Power Supplies 4 17th August 2005 10:45 AM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
Copyright 1999-2017 diyAudio
