| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Basically it's a battery feed power supply with a dual recharging option.
The output of the power supply has to be 13.2V capable of at least 3A peak draw. The source however beign an SLA, actually 2 SLAs, which will vary in voltage from 13.8V (15.2V while fast charging) fully charged down to 10.5V almost fully discharged. So I'll need some sort of DC-DC converter. The SLAs will be charged by a solar panel with 16V 1A output, actually 32 0.5V 1000mA individual cells as the primary option. This could be done by simply float charging the SLAs but since voltage from the solar cells may drop with the amount of sunlight, maybe a better option would be to have another DC-DC converter feed a proper charger circuit, eg based on a UC3906 or Maxim712, to ensure that every single mA available in the solar cells is used to recharging the SLAs. With the latter option it is also a simple matter of finding/building a power supply to feed the charger when in contact with a power grid. I would much prefer a SMPS for this. Being a total eletronics design n00b, I have the following question for you to ponder: 1) Anyone know of a DC-DC converter design that accepts 10.5V to 15.2V inputs and outputs 13.2V 3A peak? 2) Anyone know of a DC-DC converter design that accepts from 16V down to as low as possible and outputs roughly 16V 5A peak (1A peak with solar cells)? 3) I found several SLA battery charger designs on the net, anyone has a favorite (has to be switch mode)? 4) Finally I need a design for or a ready-made SMPS that accepts 240v AC and outputs around 16V (to be feed to the recharger), anyone know any good designs/makers? (I'd probably prefer a ready-made one as fiddling with high and potentially lethal voltages isn't exactly my cup of tea.) 5) Is it safe to parallel 2 SLAs or should I have some sort of switching circuitry that would charge on one battery while the other is under load, and how would you go about designing such a thing? 6) Does this all sound crazy? Am I missing something important? Comments? Btw, as a final note, I should mention that battery life is paramount so high effeciency circuits is much preferable. Thanks in advance. Johnny |
#2 |
Professional Hobbyist
Just for my basic understanding: An SLA being some sort of battery?
1) I recommend using a SEPIC topology. I dont believe you need isolation, and in its principle sepic is easy to understand. Last but not least, it can do both step up, and step down. Do some goole-ing on the topic to learn more. 2) working voltages up to 16V is probably not nescesary, as you will find that Solar voltage will drop significantly when you draw power. You might just get away without converter, having the batteries dictate the voltage delivered by the solar cells. Keep in mind that solar cells act like current sources, not like voltage sources. Find out what the IV curve is for your panel, and if your Maximum Power Point is around 13V, presto! You won't have optimum efficiency from your panels under all circumstances, but its an easy way home. Else, you should consider boost or another sepic. 3) no favorites I think you can get away with a two step charge process4) You should search the net for any wall adaptor. Maybe you can get lucky with an old laptop supply, or any other adjustable PSU. Should you have to do it yourself, I suggest you use Flyback Topology, as it will offer you isolation in the transformer. search for TOPswitch IC's that can help you design your PSU easy. Only catch will be the transformer, but i'm sure you can find help on that as well. 5) provided that SLA's are wht I think they are, I think thats fine. be sure that your converters are current limited. 6) Maybe some block schematic to help clear things up... Good luck! Bakmeel
More Power Igor! More Power! |
#3 |
for 2)...
since your open clamp voltage for the Solar cells is probably 16V, and if you choose to go without a charger, you will need an End-Of Charge switch between Solar Cells and Batteries to prevent overcharging the battery. Bakmeel
#4 |
Thanks for the information.
SLAs are Sealed Lead Acid batteries, or gel-cells as they are also know as. After reading a lot about SEPICs and flybacks, along with whole slew of other stuff, it struck me that I probably can make do with a lot less sophisticated design. I thank you for pointing me in that direction though as I could most certainly use it in a later design. Basically the output which is to feed 2 T-Amps doesn't really need a regulated output nor do they need a minimum voltage as they will cut off at roughly 9.5V by the internal protection circuit. I really only need to limit the output voltage to 13.2V, and that could be easily done by 6 diodes. A schottky in series between the plus of the solar panel to the plus of the SLAs, 4 3.6V 5W zeners in series connected in parallel with the SLAs from their plus to ground, and finally a series diode from the plus of the SLAs to the plusses of the Amps, naturally with a big cap across the rails. This should keep dissipation the lowest possible as the voltage drop from the solar cells is only 0.2V. And keep a steady float charge voltage of 13.8V while remaining within 80% of the zeners capacity. And finally would drop the maximum output voltage to 13.2V through the series diode. All I need now is a common switch to switch the SLAs between online solar charged mode and offline fast charge mode, for which I've found a suitable design. Hell, I might even be able to design an automatic relay circuit that would switch into offline fast charge mode when power was connected. I hope that this is correct, please correct me if I'm wrong. Thanks in advance Johnny |
#5 |
32 & 33 solar modules are generally considered "self-regulating". They are intended for direct connection to the battery, and in general will not overcharge the battery... much depends on your operating temperatures.
Efforts to maximize charging efficiency by boosting or bucking the solar panel's voltage are generally not cost effective for small systems... under 1000 Watts. There are exceptions to this of course, particularly where AC power is being generated. Systems where space is limited can also benefit power conversion (google MPPT... Maximum Power Point Tracking). You can get 15% more power, but on a small scale 15% more solar panel is usually less expensive. What Amp-Hour capacity are you planning? Yes, you can parallel 2 batteries... no problem at all. See the attached diagram for wiring methods... it DOES matter. Your output can be stabilized with a DC to DC convertor. Many sources for these. I can recommend many but I don't know what you have available. Purpose-built battery chargers can be problematic... usually they are very noisy. So... charging while using the load can cause problems. Power supplies can make good, quiet chargers, but they MUST have an important feature, RECTANGULAR CURRENT LIMITING or CONSTANT CURRENT LIMITING. An RKW 15-10K from Kepco is an excellent choice. http://www.kepcopower.com/rkwo.htm The key to long battery life is avoiding deep discharge. At light loads your battery should never be discharged below 12.0 - 12.2 Volts. |
#6 |
Account Disabled
Does that recommended wiring scheme solve non equal load issues when it comes to charging? I've seen the same scheme recommended for psu caps in // and it makes alot of sense to use it.
I'm think the real high end way would be two sets of SLA's, whereby you can silently swap from in use to charging automagically, I guess the purpose of that would be to keep playing at full power and not risking hearing the supply being charged. Is it practical though? |
#7 |
Yup,
In fact, I made that crappy drawing for a cap discussion. Each cap, OR battery see an equivalent resistance and inductance looking out. I build inverters (100kW ClassD if you will - ), and this type of wiring is essential. You can basically melt caps (and batteries) if wired wrong. It all makes sense when you compare the the ESL & ESR of the caps to the interconnecting wires.I think a single set of batteries with an RF trap betwen the batteries and the load would be just fine... and cheaper.
#8 |
Account Disabled
I dunno, could such a beast not also help by keeping a more stable supply, less variation under load that is, since you can set whenever they switch over. Not to mention the extra juice could add to run time if going full solar. Kind of have a semi controlled sag rate based on available charge. Then we can say it's novel and charge 10X the price.
So far this hasn't sounded like cost is a big factor. 'bout the wiring, I"ll have to try and see how that applies to 4 pole caps, could be worth it, and thanks for sharing that. Cheers |
#9 |
Depending on the size of his batteries, sag should not be a problem... SLA's pretty damn stiff as far as that goes.
The Zee wiring is a fine point with caps in typical applications. In app's where the caps are highly stressed (full rms currents), it is essential though. I don't allways do it. I sometimes apply the same techniques to paralleled FETs & IGBTs... mostly for balancing stray inductance. Batteries are a different matter... small changes in voltage translate to large changes in (dis)charge currents etc... OH... and BTW you don't need to disconnect the solar panel when using the charger. You WILL want a diode in series with the charger to prevent discharging the batteries through the charger's internal reisitors though. |
#10 | |
Account Disabled
| Thread Tools | |
| Anyway to resurrect some NiMH Cells | kvk | Everything Else | 17 | 27th May 2008 04:53 AM |
| Audio Switcher involving Optical and Stereo In, 5.1 Out | hsadan | Parts | 0 | 4th July 2007 02:34 PM |
| 9V from 2 AA cells | space-cake | Parts | 6 | 7th October 2006 04:05 PM |
| Projects involving EF50 tubes? | Emnitec | Tubes / Valves | 10 | 6th February 2006 10:42 PM |
| How to make Fuel cells ?? | jacquesl | Everything Else | 8 | 24th March 2005 08:53 PM |
| Page generated in 0.28868389 seconds (80.26% PHP - 19.74% MySQL) with 11 queries |
