Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th July 2006, 08:41 PM   #21
poobah is offline poobah  United States
poobah's Avatar
Actually, the Vmax spec. on the T-Amp is questionable... double check it. It is a class D amp so I don't think some variation on the power supply should hurt much, but spec's are spec's and you must follow them...
Now, you are solar charging the batteries... so 14.0 - 14.1 is a better value then 13.8.
So the problem is how to get down from the 14.0 at the battery to the 13.2 (max) of the T-Amp... you could use another shunt regulator, you could use a "LOW Dropout, 3 terminal, 12 Volt regulator". OR, you could use two regular diodes in series for a drop of 1.2-1.4 Volts... very simple.
Mcuh depends on how you plan to do your AC charging. Any decisions there?
Old 26th July 2006, 09:09 PM   #22
Saturnus's Avatar
Originally posted by poobah
Much depends on how you plan to do your AC charging. Any decisions there?
I'm leaning towards this
http://www.ham-kits.com/SLACharger1.htm
schematics here
http://www.ham-kits.com/SLACharger/SLA%20Charger.pdf
I'll need to modify it for 240V AC, though but that's pretty simple.
Old 26th July 2006, 11:54 PM   #23
Saturnus's Avatar
I couldn't just let it rest, could I?
A quick search in the local parts shop junk pile revealed some BD536 (datasheet below).
It's TO-220 package, has relatively low Hfe (min 40), and is relatively low frequency.
If I dropped that into your circuit using the components which I desribed above (not correct voltage, I know, but I can ix that later) then R(base) would have to be 1K1ohm but I assume I could use a 1Kohm. Correct?
If so, then I'll have a look at the other numbers tomorrow to increase the voltage slightly. And still assuming it's correct, I don't see any reason why I couldn't and shouldn't use an identical circuit for dropping the voltage from the battery to the load. With different values naturally.
Datasheet: http://www.ortodoxism.ro/datasheets/...onics/4133.pdf
Old 27th July 2006, 12:10 AM   #24
poobah's Avatar
You want to sink (shunt) 1 amp solar max. Divided by Beta min equals 0.025 amps. You have 10V max or so across the base resistor to accomplish that... So that gives you 400 ohms max for Rbase.
Perhaps a "PNP darlington" would be a better choice because of it's higher beta. The TL431 should not have such a high current.
Now, a shunt regulator is handy for a solar panel because a solar panel is really a current source... not a voltage source. Your battery on the other hand is definitely a voltage source. Research the low dropout 3 terminal regulator.
oh...get some sleep!
Old 27th July 2006, 05:06 AM   #25
poobah's Avatar
Something else to think about here... a shunt only diverts current when an excess of voltage commands it to do so. In the case of the solar panel, it will only divert current when the battery reaches 14 Volts... in other words charged... doesn't need the current.
Now what happens if you use another shunt to regulate the battery voltage down for the T-Amp???
Hint: keep in mind you do have to put a resistor between the battery and the shunt to do this.
Anyway to resurrect some NiMH Cells kvk Everything Else 18 26th April 2010 09:38 PM
Projects involving EF50 tubes? Emnitec Tubes / Valves 11 9th March 2010 04:21 PM
Audio Switcher involving Optical and Stereo In, 5.1 Out hsadan Parts 0 4th July 2007 02:34 PM
9V from 2 AA cells space-cake Parts 6 7th October 2006 04:05 PM
How to make Fuel cells ?? jacquesl Everything Else 8 24th March 2005 08:53 PM
Page generated in 0.09510 seconds (78.11% PHP - 21.89% MySQL) with 11 queries
