How to dismantle transformer? - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd July 2006, 10:19 AM   #11
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
I think it would be best if you would put it in boiling water for 10min+.It worked for me.But i did damege the bobblin in the process,but it can be done.
Old 22nd July 2006, 11:39 AM   #12
Did it Himself
richie00boy's Avatar
In the transformer factory I worked in, we used to soak the transformers for rewinding in solvent.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 22nd July 2006, 12:50 PM   #13
luka's Avatar
What kind of solvent
Old 28th July 2006, 05:42 AM   #14
Methods of removing it is to dip the whole tranny into thinner. The thinner will dilute the varnish making it easier to work with.
Also another way to liquidfy your varnish is to bake the trannies to 180-200C. At this temperature varnish will start to liquidfy and will start to flow out of the trannies(position them in a way the varnish can flow).
Also use some form of vibration while trying to remove the core will help.
I use this method when trying to remove trannies for rewind at our tranny workshop
Hope this helps
Nicholas
Old 28th July 2006, 07:06 AM   #15
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
If your core is a laminated type what has always worked for me is a stove element. Put in on there sometimes with a lid overtop works fine. I think boiling or water in general will corrode or damage the material. Getting the first E is the hardest and may be damaged, while its warm you can usually break or pry apart sections in no particular order. Re heat and repeat until its done. I've never wrecked the plastic bobbin either.
Old 29th July 2006, 07:22 AM   #16
ifrythings's Avatar
Heat gun on it for a few minutes and all the laminations fall out (with a small touch of the finger of course )
The transformers I'm dismanteling are ferrite. (But thanks for the suggestion for Laminated ones).
The heat gun works on the ferrite ones, but I got two apart and 3 cracked in the heating process
Old 29th July 2006, 07:24 AM   #17
ifrythings's Avatar
Ya richie00boy, what solvent do/did you use?
Old 29th July 2006, 05:21 PM   #18
Did it Himself
I can't remember TBH. I think it was a celulose thinner.
Old 30th July 2006, 12:56 PM   #19
TonyTecson's Avatar
i use lacquer thinner, i dipp the trafos in a tub full of thinner until the varnish softens up, when that fails, i just use a hacksaw and cut away the copper windings....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old amp-rebuild or dismantle? taylor Tubes / Valves 30 6th July 2002 10:39 PM
Copyright 1999-2017 diyAudio
