Hi
how can I use this eschematic (or a simple one like this) to work with a sec. 24-0-24V, 5A transformer and give 30v (bipolar)? I can't find a schematic to give 30-0-30. I hope someone can help me. thks all |
#2 |
Did it Himself
The schematic is the same whatever you do. All that is different is that for 30-0-30 volt output you need a 22.5-0-22.5 volt transformer, which you will be unlikely to find.
I'm sure a common 25-0-25 volt transformer yielding 33.5-0-33.5 volts will be fine.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
thaks thanks thanks.
what a stupid question....but now I'm happy.lol thks again |
#4 |
#5 |
well...you can also place 0.1uf in parallel with each diode of the bridge if you want...They reduce HF noise caused by the reverse recovery current being snapped off when the carriers in the diodes are depleted.
| Bipolar Variable Power supply for protoboard | jman 31 | Power Supplies | 10 | 24th March 2009 03:39 PM |
| Grounding for Mixer and Bipolar Power Supply | bbmonster | Instruments and Amps | 1 | 20th March 2009 08:59 AM |
| Bipolar Power supply IC | argonrepublic | Parts | 1 | 6th December 2008 08:24 PM |
| Regulated Power Supply. Bipolar, JFET or MOS? | Kenneth Zhu | Tubes / Valves | 4 | 30th December 2007 09:30 AM |
| simple power supply question..... | Luke | Pass Labs | 5 | 31st March 2004 07:22 AM |
| Page generated in 0.07169 seconds (71.61% PHP - 28.39% MySQL) with 11 queries |
