Go Back   Home > Forums > Amplifiers > Power Supplies
Old 6th July 2006, 03:52 AM   #1
Wombat2 is offline Wombat2  Australia
Wombat2's Avatar
Default Convert single to dual supply
I bought one of these on eBay Click the image to open in full size. but then discovered it was single rail supply not dual. the connection for GND is just that - chassis ground with no potential between the +/- and the GND terminal.
Is there anyway I can get some sort of dual supply even temporaly for low voltage testing before applying full power to a new project?
Otherwise it's a good little power supply
David L
Old 6th July 2006, 04:18 AM   #2
ostie01 is offline ostie01  Canada
One way of doing that is you can place 2 high wattage resistor in serie between + and ground. The + become the positive power supply, between the 2 resistors is the potential ground and the ground of the power supply become the negative .Both resistor must be of equal value since you do not want your groung having +/- a couple of volts.
This is one way that can be use easily and pretty fast, good luck
Old 6th July 2006, 05:23 AM   #3
Use a power opamp and make a virtual ground.
Gajanan
Old 13th July 2006, 10:44 AM   #4
Hello!What's "chassis ground ",please?Do you mean that this power supply is broken?Thanks
Old 13th July 2006, 10:47 AM   #5
Did it Himself
richie00boy's Avatar
Gajanan
Yes see the virtual earth for car audio project on the ESP site. Don't expect much out of it though, but then again the supply is probably pretty weak anyway so may well be complementary.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 13th July 2006, 10:48 AM   #6
Did it Himself
Chassis ground means it's just a terminal connected to the case and presumably mains earth. Otherwise the supply is floating, this gives you the option to earth it.
Old 13th July 2006, 11:12 AM   #7
traderbam's Avatar
How much did it cost on Ebay? If cheap enough you could always buy another one and wire them in series, assuming they have
floating outputs.
Old 13th July 2006, 11:52 AM   #8
Did it Himself
I would imagine with the separate earth terminal they would be fully floating
Old 14th July 2006, 05:03 AM   #9
richie00boy,thanks for your explanation.
Wombat2,
I happen to found such a powersupply yesterday.Refer to the following pictures.I opened it last night and I found that there was only a large transformer and several pieces of PCBs in it.So I advice you to mend it for yourself,if it is possible.Make sure that you will not be shocked by the input current.Good luck.
Old 14th July 2006, 08:35 AM   #10
Did it Himself
there is nothing to mend. He just needs a supply splitter or another supply the same.
Single Supply to Dual Supplies edpgc Car Audio 0 22nd November 2007 10:36 AM
How to convert S5 K-12g kit to dual mono? downward_dog Tubes / Valves 4 11th January 2007 12:57 PM
Lm1875, Single Or Dual Supply alcuemar Chip Amps 5 24th May 2006 03:02 PM
Single ended classA with dual supply rails boxedin Solid State 9 11th January 2006 10:02 PM
Interfacing dual and single supply parts? CryingDragon Solid State 2 5th December 2002 06:26 PM
Page generated in 0.12830 seconds (74.39% PHP - 25.61% MySQL) with 11 queries
