My Soft-Power Circuit
Old 17th June 2006, 06:53 AM   #1
maxw is offline maxw  United Kingdom
maxw's Avatar
Default My Soft-Power Circuit
I just thought I'd share the Soft-Power Circuit I made. Someone might find it handy and eagle files are attached so others can etch their own and change it to suit them. Its based on these two designs using a 4013 flip flop:
http://www.cpemma.co.uk/flipflop.html
http://maxhawk.flagshiphosting.com/p...onv2/index.htm
It basically just lets you use a nice little momentary switch to activate a relay for switching amps, preamps or whatever on and off, just like a bought one
Mine uses a transformer from Jaycar which is exactly like an Amveco one but it is 45mm square instead of 50mm. I will be using a solid state relay.
Pics:
Old 17th June 2006, 09:46 PM   #2
maxw's Avatar
I forgot to attach the eagle files.
Old 19th June 2006, 06:34 AM   #3
excetara2 is offline excetara2  United States
Thanks a lot. I might need that. Some good pictures by the way.
Old 19th June 2006, 09:06 PM   #4
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
That's great, but a bit of an overkill. First, note that it can be done without the transformer if the on-off signal is allowed to be mains live. Second, the solid state relay may be replaced by a triac and triggered by a compact 8 pin microcontroller, that may also achieve other functions like phase controlled soft-start, brownout detection, frequency checking, overvoltage and undervoltage protection, emergency shutdown, etc...
That's how I would do it.
I use to feel like the small child in The Emperor's New Clothes tale
Old 19th June 2006, 09:10 PM   #5
maxw's Avatar
Well, post up your schematic and PCB layout then
Old 20th June 2006, 03:11 AM   #6
kASD is offline kASD
kASD's Avatar
Have a look at this Soft-Start using IGBT.....
regards,
K a n w a r
Old 20th June 2006, 03:52 AM   #7
Bratislav is offline Bratislav  Australia
Default short lived
it looks like your IGBT might fire (sic) only once
Old 21st June 2006, 02:16 AM   #8
sawreyrw is offline sawreyrw  United States
Workhorse,
It won't work. You can't turn the IGBT on without a positive gate supply.
Rick
Old 21st June 2006, 02:28 AM   #9
maxw's Avatar
Originally posted by Eva First, note that it can be done without the transformer if the on-off signal is allowed to be mains live.
Also, one of the main motivations for using my circuit is so that you can use nice looking switches on your equipment and most of them will not take 110/220V, eg the bulgin switches:
Old 21st June 2006, 02:34 AM   #10
kASD's Avatar
Hi Rick,
If you look at the optocoupler, its actually a Photovoltaic Driver from IRF which upon LED activation in it produces a voltage for gate drive of IGBT by the virtue of Photocells arrayed in it......
So theres no need of external supply apart from triggering the LED which could simply powered up by small rectified voltage scale down from mains AC itself.....
Have a look at this:
http://www.irf.com/product-info/data.../data/pvin.pdf
K a n w a r
My Soft-Power CircuitHide this!Advertise here!
Soft start circuit Diode Solid State 19 14th January 2013 07:38 PM
ESP soft start circuit 454Casull Power Supplies 19 29th May 2009 02:06 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
