#11 |
Considering parameters like whether this is a one-off or a design for production, and how much you value your time, you may well be tempted to go back to your original idea of using DC/DC converters.
For example, my local RS sells the RECOM RI-1212 at EUR 9,69 (QTY 11+). These will do 12V/12V, 2W and are rated at 1kV isolation, 10 GOhm || (30-85pF). You'll have a hard time beating these 50pF with a multi-secondary 50 Hz trafo, or the 10 EUR with a bunch of homemade flybacks (if you figure development time, assuming small quantities - 10+k pieces is another story altogether).
--WD |
#12 |
one more idea ... combine powerbecker's suggestion of using cheap common-mode chokes as transformers with DL2YEO's wondrous ways of using halogen lighting "transformers" (really small SMPS) - http://www.qrp4u.de/docs/de/tube_smps/index.htm
In short, open a 60W "electronic halogen trafo", add a primary cap to get continous output, then feed the 12V 18 kHz (or what you get) to a bunch of 1:1 chokes, rectify and filter. Using separate little trafos lends itself nicely to modular construction. Alternatively, you might manage to put 24 * (a couple of turns) directly onto the toroid normally found in one of these. The toroid is usually plastic-potted for primary insulation (DL2YEO has pics).
--WD |
#13 |
Cheap small power supply ???
here (also a nice service!): http://www.pollin.de/shop/shop.php click left side: "Stromversorgung" than: "Netzgeräte" than "Steckernetzgeräte" or "Festspannungs-Netzgeräte" Regards Heinz! |
#14 |
Or similar to wine&dine said:
Buy yourself a bunch of cheapo 230V to 24V adaptors, rip em out of their casings and put them in your application... Cheers Bakmeel
More Power Igor! More Power! |
| 18v bi-polar dc/dc converters | argonrepublic | Power Supplies | 1 | 7th January 2009 07:47 PM |
| D to A Converters | dgonsior24 | Parts | 1 | 4th July 2007 01:15 AM |
| D/A converters | elojaudio | Digital Source | 9 | 16th July 2004 08:49 PM |
| DC to DC converters | Paulr | Car Audio | 6 | 16th June 2003 02:35 PM |
| looking for audio converters | andyg | Introductions | 0 | 25th January 2002 05:19 PM |
| Page generated in 0.09135 seconds (76.77% PHP - 23.23% MySQL) with 10 queries |
