Go Back   Home > Forums > Amplifiers > Power Supplies
Old 9th June 2006, 03:03 PM   #1
Default Using unregulated AC wall wart
As the topic says, I'm going to use a 16VAC wall wart to power a DAC. The DAC will have onboard regulation using LM317/337. Basically, I'm doing this to avoid dealing directly with transformers and mains power, as a safety issue. After the rectifier, is it enough to use one large electrolytic (4700 uF) to smooth the ripple before the regulators? What would you guys do in my situation?
Old 9th June 2006, 03:27 PM   #2
How do you plan to get +/- supplies out of a single AC winding?
What voltages do you want to end up with?
At what currents?
Are they balanced?
Old 9th June 2006, 03:46 PM   #3
I thought the +/- is supplied directly from the wall wart coaxial plug. It came with a schematic of the transformer, but I don't have it on me right now. I'll check tonight.
As for the voltages, I want to end up with +/- 12, +5, +3.3 for the various sections. The current draw should be well under 1 A, but I can't say for sure right now.
Old 9th June 2006, 04:15 PM   #4
AndrewT is online now AndrewT  Scotland
using about 2mF per A is usually enough for accepatable ripple before the reg.
Your 4m7F should easily cope.
There was a thread recently where a single AC winding was purportedly giving +-DC output. I am not sure the poster knew what he was proposing, worth searching for and try to fathom his schematic.
regards Andrew T.
Old 9th June 2006, 04:16 PM   #5
astouffer's Avatar
http://tangentsoft.net/elec/vgrounds.html
Old 9th June 2006, 04:27 PM   #6
Now I understand what I proposed doesn't make sense. I just don't want to mess with transformers. Well, I guess I can try the virtual ground, but in that case, I will need a much higher AC input (~30), which would give +/- 15 pre-regulation. The highest (AC) voltage wall wart at mouser is only 24VAC, so that's not going to cut it. I suppose I will have to either a) go for an external PSU that has dual outputs (+/- 15) or b) just get over my fear of high voltage and get a center-tapped transformer.
Old 9th June 2006, 05:48 PM   #7
megajocke's Avatar
I used two half-wave rectifiers to get + and - voltage out of a wall wart. But then my load was small. Just two op-amps in a Linkwitz Transform circuit. It might not work too well if your current draw is unbalanced. I guess using a full bridge and an active virtual ground would be better in that case.
Old 9th June 2006, 06:59 PM   #8
preiter is offline preiter  United States
preiter's Avatar
Check out...
http://sound.westhost.com/project05.htm
Old 9th June 2006, 07:41 PM   #9
Brilliant! That's exactly what I was hoping for. I should be able to use LM317/337 instead of the fixed regs, right? Thanks, mucho.
Edit: Apparently, there is an update to that project (cleverly P05a), specifically, to use adj regs.
http://sound.westhost.com/project05a.htm
Old 9th June 2006, 08:59 PM   #10
paulb is offline paulb  Canada
There's an error in this schematic; C28 is upside-down.
Wall Wart for testing bal704 Chip Amps 6 23rd October 2006 01:47 AM
best wall wart for t-amp, where? gychang Class D 3 2nd October 2006 12:06 PM
2 Wall Wart PS Question Sherman Chip Amps 13 22nd February 2005 09:25 PM
Another Wall wart question JCoffey Chip Amps 14 2nd December 2003 05:54 PM
Page generated in 0.12360 seconds (69.56% PHP - 30.44% MySQL) with 11 queries
