Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th May 2006, 02:43 AM   #11
redrabbit's Avatar
WoW...thanks for the great suggestions. I have yet to research all of them.
It is a vintage Simpson, 0-100mA, no other writing on the face. It's has a bit of weight to it, if that adds to any speculation about it.
Yes, I will save this meter for a more elegant situation ; my need for a meter is to quickly measure volts and load for:
*4 variable PSUs (in a single box),
*up to 12v / 200mA.......to power guitar fx,
*using a three-position momentary switch on/off/on... (volts/off/milliamps)
*another rotary switch points to which supply output I want to adjust/check.
...the reason for the momentary switch is to keep the meter out of the circuit, except when needed.
=RR=
BTW: Lackinnj....funny, I was just searching for Jfets today, at my local surplus store....2n5457......they didn't have any.
Old 26th May 2006, 08:51 PM   #12
Stocker is offline Stocker  United States
World politics left aside for the moment, there are several companies producing low-cost panel meters that are getting down into the $20-$30 range IIRC. And for cheaper than that you can get a DMM from an auto parts store to mount and leave, dedicated, in-circuit.
Jesus loves you.
Help! How to measure 2450 volts with 1000 volt max meter. ichiban Parts 8 6th June 2009 04:10 AM
Kenwood VT176 / 175 milli volt meter ashok Everything Else 3 25th April 2008 04:39 AM
Wiring Digital Volt Meter Dominick22 Chip Amps 19 24th April 2006 06:58 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 12:22 PM
I need a portable diy electronic AC volt meter, to avoid transportation of Scopes. destroyer X Solid State 10 21st August 2005 06:38 PM
Page generated in 0.07040 seconds (65.91% PHP - 34.09% MySQL) with 10 queries
