Go Back   Home > Forums > Amplifiers > Power Supplies
Old 24th May 2006, 07:10 AM   #1
deduikertjes's Avatar
Default LM337 behaving strange???
Help,
I've build a pretty straightforward negative supply for my pre-amp using a LM337, which behaves well with a ouput voltage of 15.1 V (as designed).
Now comes the strange part: As soon as I ad the Adjustment pin bypass capacitor (10 uF or 22 uF) the voltage drops to about -8V. When I remove Vin the output voltage first increases to about -13 V before decreasing to 0V.
I've tried several cap's. Who knows what's happening and how this can be solved? (Of course I want the adjustment bypass capacitor because of the lower noise and impedance when used.)
thanks and greetings, MArco
Old 24th May 2006, 07:18 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
You are aware of the different pinning compared to LM317?
Can you show us how the circuit look like? Resistor values? It's a bit sensitive not having too large values between OUT and ADJ.
/Per-Anders (my first name) or P-A as my friends call me
Old 24th May 2006, 09:28 AM   #3
Yes, I am aware. It works fine without the adjustment bypass capacitor. It would'nt when I've got the pinning wrong. Or would it?
Well the circuit looks pretty much like the attached. The differences:
R1 = 120
R2 = 1320
C2 tried 10uF and 22 uF. Both with same results.
Added 0.1 uF from Vin to ground.
Tried with and without the protection diodes.
Omitted Cl. I want that one near the load. Now that I think of it, could that be the problem
Old 24th May 2006, 09:45 AM   #4
Did it Himself
richie00boy's Avatar
If you read the datasheet again it tells you to keep Cl near the regulator to minimise problems with inductance from the traces reg to cap.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 24th May 2006, 09:53 AM   #5
peranders's Avatar
You must also have a cap at the output. Use 1-10 uF or so, see datasheet.
Old 24th May 2006, 10:02 AM   #6
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
You may have the cap reversed, that would cause a large leakage current, giving exactly the thing you see. The + terminal of the electrolytic should go to ground.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 24th May 2006, 10:35 AM   #7
Did it Himself
Cl is the output cap, so he is ok
Old 24th May 2006, 10:57 AM   #8
peranders's Avatar
Yes, but if you have too little the LM337 can oscillate and 337 is more sensitive for that than 317.
Jan's idea might also be something.
Old 24th May 2006, 11:47 AM   #9
The adjust bypass cap (C2) does have the positive side to ground. I actually measured the voltage across the cap to be double sure.
Marco
Old 24th May 2006, 12:53 PM   #10
Did it Himself
Sorry you are right he had omitted Cl.
YOU NEED Cl
Help with mis-behaving Cambridge 540A J Wiggle Solid State 16 Today 08:57 AM
CDM2/10 Behaving Badly Dave S Digital Source 71 26th May 2010 10:52 AM
5687 Linestage behaving odd... bibster Tubes / Valves 22 15th April 2006 07:27 AM
LM337 problems jarthel Digital Source 7 11th June 2002 09:06 PM
Page generated in 0.10587 seconds (78.21% PHP - 21.79% MySQL) with 11 queries
