Variable 10-14Volt 10-15A BUCK requlator
Old 17th May 2006, 07:05 AM   #1
sivan_and is offline sivan_and  India
sivan_and's Avatar
Send a message via Yahoo to sivan_and
Default Variable 10-14Volt 10-15A BUCK requlator
Designing a Variable 10-14Volt 10-15A BUCK requlator
Application: Lead acid battery charger/HAM psu
TL494 PWM o/p volts and current limit>> high side driver > high side n-ch power mosfet Z44/48 high current torroid inductor/ fast recovery diode...
all inputs welcome...
thanks
Sivanand
SivanandBalan
Old 17th May 2006, 07:35 AM   #2
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
You haven't consider to buy a dirt cheap charger if the main purpose was to get the battery charged?
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 65 pcb's in order. 59 paid.
Old 17th May 2006, 10:33 AM   #3
sivan_and's Avatar
Need a highly efficient charger..no Thyristor or linear...
SivanandBalan
Old 17th May 2006, 10:57 AM   #4
peranders's Avatar
Yes, but many of the dirt cheap from China is pretty effecient. A linear charger is hardly effecient if I mean the same thing as you.
I just checked at www.biltema.se and 9 A charger for 30 USD, 5 A for 20 USD!
It's called "Batteriladdare" if you want to check, only in swedish though. I'm pretty sure you can get a decent charger in India.
Old 17th May 2006, 11:23 AM   #5
sivan_and's Avatar
I wish to DIY...
looking for a high side driver for the MOSFET..even though i have IR2110 i don't want to waste it (the low side driver will not be utilised.)...
SivanandBalan
Old 17th May 2006, 11:30 AM   #6
sivan_and's Avatar
and i have most of the stuff lying ..2 inch torroids,power transformers,metal cabinets..etc...etc..and will be in junk soonf i am not using these anyway...
SivanandBalan
Old 18th May 2006, 03:59 PM   #7
sivan_and's Avatar
step 1:
crude schematic: how to make it w/o high side drivers
SivanandBalan
Old 18th May 2006, 04:06 PM   #8
Danko is offline Danko  Hungary
I'm experimenting with a 12V Lead-acid battery charger, for 20A. I can send the final schematic, when I'm finished. This is a constant current schematic, based on LM2574-ADJ. This is a 0.5A DIP-8 packaged device. I "boosted" the current with a 80A "cute" MOSFET :-)
After that I will have to make a 2-12 (of 2-15V) supply, for about 15A, for powering a few stepper motors. I don't know, how will I make that. Maybe I will use LM2574-ADJ, and some current-boost MOSFET, but this LMxxxx IC can operate only at a fixed, 52kHz frequency, so I will need quite big output choke.
Best regards, Danko
Old 19th May 2006, 01:31 AM   #9
sivan_and's Avatar
....but u need to limit current to C/10 or better C/20..right ?
SivanandBalan
Old 19th May 2006, 03:32 AM   #10
ifrythings is offline ifrythings  Canada
ifrythings's Avatar
Are you driving this from mains voltage??
If you are, you have a good desgin for killing people (or things)
Variable 10-14Volt 10-15A BUCK requlatorHide this!Advertise here!
most bang-for-the-buck sub-amp skogs Solid State 12 8th September 2007 10:22 AM
buck regulator jamesrnz Power Supplies 13 11th June 2007 06:12 PM
SMPS - Buck converter - HOW !? -_nando-_ Power Supplies 20 19th December 2005 02:14 AM
best boom for the buck? peace brainerd Subwoofers 10 15th December 2005 09:56 PM
Buck & boost transformer Ilianh Parts 1 15th March 2004 06:03 AM
