Planar transformers
Planar transformers
Old 16th May 2006, 02:19 PM   #1
TroelsM is offline TroelsM  Denmark
TroelsM's Avatar
Default Planar transformers
Hi.
Found this while browsing the web: http://www.manz-electronic.de/index/...alogue2005.pdf
Search for "planar transformer". Looks interesting!
Regards TroelsM
Need more time...
Old 16th May 2006, 02:28 PM   #2
Pierre is offline Pierre  France
Banned
It turns out that I tested one of that planar transformers from Premo, it was a model of around 520W if I remember well, designed for Half-bridge AC/DC and +/-48V output. The results were very frustrating for me.
The first difficulty was the required frequency of operation, around 200KHz. At that frequency, you need very fast switching, so mosfet must be driven with great care, edges are very sharp and EMI is likely to be a problem.
Besides that, you will need shottky diodes for rectification, that are very difficult to find with the required voltage and current ratings (150V at 10A or so).
Needless to say, the same circuit design with much more standard components worked at first attempt for me, and very efficiently, using a ETD44 core I wound myself
Not to talk about the cost... planar transformers are expeeensive.
Planar transformersHide this!Advertise here!
diy planar... again ionomolo Planars & Exotics 4 29th January 2015 12:34 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
Planar 78 ? Navin_R_Johnson Analogue Source 11 19th March 2006 08:30 AM
New BG planar mid.. ScottG Multi-Way 1 6th February 2006 07:50 PM
Anyone played with Planar Transformers? Danko Power Supplies 7 25th December 2005 03:41 PM
